Brake Light Issue
Old Jun 12, 2015 | 04:09 PM
Dan89FLSTC's Avatar
Dan89FLSTC
Active Streak: 30 Days
You have voltage at the bulb socket? How did you check this?
The brake light socket, is it stock , did this bike originally use a regular bulb (non LED)?
Old Jun 12, 2015 | 04:16 PM
Sunday's Avatar
Sunday
You have voltage at the bulb socket? How did you check this? The brake light socket, is it stock , did this bike originally use a regular bulb (non LED)?
I just checked it with a test like before coming to work today. My multimeter was in my box here at work. When I purchased the bike it had an LED light in it and I changed it out to a Tribar.
Old Jun 12, 2015 | 04:20 PM
Dan89FLSTC's Avatar
Dan89FLSTC
I`m thinking that the ground is suspect, because when you use the test light, you clip it to a good ground, bypassing the ground the light normally uses.
I`m looking at a wiring diagram for your bike, but of course it only shows the oem setup...
Make sure the black wire is secure in the terminals.
Old Jun 12, 2015 | 04:30 PM
Sunday's Avatar
Sunday
I`m thinking that the ground is suspect, because when you use the test light, you clip it to a good ground, bypassing the ground the light normally uses. I`m looking at a wiring diagram for your bike, but of course it only shows the oem setup... Make sure the black wire is secure in the terminals.
Thanks, I'll check it out when I get home and see how it goes.
Old Jun 12, 2015 | 04:32 PM
Sunday's Avatar
Sunday
I have running lights though, don't they share a common ground?
Old Jun 12, 2015 | 04:37 PM
Dan89FLSTC's Avatar
Dan89FLSTC
There is a ground wire coming from each lamp socket, they all merge at some point in there, but if the wire or connection is bad between the socket and where the ground wires merge, it will affect only one lamp.
Jason1977
Apr 3, 2023 04:43 PM
Damien Bessent
Sep 20, 2022 03:36 PM
beary
EVO
Jul 18, 2015 08:21 AM
code.mafia
Electrical/Lighting/Alarm
Jun 10, 2009 02:57 PM
psycocavr
May 2, 2007 02:24 AM
