1997 softail 1340 Custom
Old Sep 19, 2005 | 12:41 PM
palaima1's Avatar
palaima1
Default 1997 softail 1340 Custom
Help!...I stopped for gas yesterday and like a FOOL turned my petcock off...fueled up and started bike going own the road the bike started to lose power...I REMEMBERED the petcock was off reached down tuned it on and continued to ride for about 4 miles when the bike died. Got it home pulled the fuel line from the petcock and didn't get any flow from it in any position. Took the petcock out cleaned and reasembled it (*like an #$%^$ after I reassembled it I blew through it) ...reinstalled the petcock turned it on and had good flow. NOW the bike won't start. I pulled the plugs and get good spark on each. I pulled the air cleaner and get gas to the carb. Could this be a diaphram problem on the vacuum side of the petcock? How do I know if the choke is working right? The bike just sputters and occasionally backfires through the exhaust but WILL NOT START.
bob
Old Sep 19, 2005 | 01:37 PM
TxMoores's Avatar
TxMoores
Default RE: 1997 softail 1340 Custom
Well... just to make sure you don't have water and crap in your carburetor causing you grief you should pull you bowl off or drain the bowl (not sure which carb you have) and clean it out. My vacuum petcock gave me some fits (decided it wanted to turn off during a couple of rides) so I fixed it by removing the vacuum line and installing a high flow petcock. No more problems. I got mine from J&P, but it seems like everyone carries them and they are fairly cheap!
Old Sep 19, 2005 | 01:43 PM
palaima1's Avatar
palaima1
Thanks for the info...I think it's all related to the damn vacuum petcock...I did drain the bowl...still doesn't fire up...are the backfires through the exhaust a sign of fuel starvation?
Old Sep 19, 2005 | 01:53 PM
TxMoores's Avatar
TxMoores
Yes, it can be caused by fuel starvation, jetting problems and ignition, but since you are already having fuel delivery problems that would be a good place to start. You might IM TCSTD for his thoughts as well... he is our wizard.
Also, check out --> https://www.hdforums.com/fb.asp?m=69614
Old Sep 19, 2005 | 01:58 PM
palaima1's Avatar
palaima1
will do ...thanks for reply....
Old Sep 19, 2005 | 09:58 PM
pococj's Avatar
pococj
Get rid of the vacuum operated petcock. IMNSHO, those things are for people who are too forgetful to ride a bike.
Old Sep 20, 2005 | 11:07 AM
dert's Avatar
dert
Agree.Loose the vac.petcock .Easy enough.Mine had a vac.on it which was added by the previous owner and I had trouble from the start,changed over and trouble free.
William Frick
Carburetor Related
Sep 30, 2017 07:23 PM
crashin541
May 19, 2017 01:29 PM
JigokuNoIkari
Apr 1, 2012 01:11 AM
scorcher2005
Mar 31, 2009 06:33 AM
palaima1
Sep 19, 2005 01:33 PM
