? is crank position sensor true/false only?
Old Jul 5, 2015 | 03:35 PM
amkaos's Avatar
amkaos
Default ? is crank position sensor true/false only?
Either it works or it doesn't?
And if it is bad, will the bike start or would it have intermittent troubles?
Thx
Old Jul 5, 2015 | 04:08 PM
Tampa Fatboy's Avatar
Tampa Fatboy
Old Jul 6, 2015 | 03:20 PM
olongapo1's Avatar
olongapo1
The Crank Position Sensor is a magnetic pickup sending a signal which is related to spark timing. Normally it is functioning or not functioning however I suppose that if the magnetic field has weakened, a correct signal could be intermittent. They are inexpensive. If yours is suspect just replace it.
Old Jul 9, 2015 | 10:23 PM
amkaos's Avatar
amkaos
Well I had intermittent hard starting problems..
Even tho the sensor tested fine voltage wise, I replaced it..
Starting problems were fixed..
flhrc2009
Electrical/Lighting/Alarm
Nov 17, 2025 12:45 AM
Ultra RB
Apr 1, 2016 10:01 PM
Moe55
Oct 8, 2015 08:07 PM
dlwilson72
Jun 10, 2009 07:50 PM
hogdoctor
Sep 2, 2008 11:56 PM
