I rode it to work this morning and tried starting it up to go home and I hit the run switch and that worked fine. Then tried starting it and all I get is a click..
I'm about to drive my car to it and try to pull some codes off of it and then bring the battery back to my room and put it on the tender.
Anyone have any suggestions? I searched and read some other posts about the same problem and thats what has dictated my current approach.
DTC B2124 will set if the starter solenoid circuit draws more than 12 Amps
I'd give it a try with a fresh charged battery, and if it starts be ready to measure the charging voltage, if it's > 13.6 volts the charging circuit should be good and must be some parasitic load that drained it.
That code suggests an over current issue, .... not sure how it determines that, ... could be looking at the voltage drop from the time you hit the start switch.
Could be the battery is not discharged, and the cause is a poor connection.
