Oil tank fittings
Going to do AN lines for my oil lines on my bike and was wondering if anyone knows what the fittings are in the tank? I need fittings to go from that to AN.
Edit: it's a twin cam oil tank by the way
Carefully pop the chrome covers off the top lines (use a small screwdriver if you must, but you should be able to do it by hand with your fingernails). You'll see a plastic clip that you squeeze and you can pull the lines out. There's an o-ring inside the female part of the tank that seals it.
I don't know of an AN fitting that works with these. Maybe there is? Of course you could cut the steel lines after that factory fitting and use a compression fitting I guess...seems like a kludge to me however....and a great place for a leak to start...
The bottom lines are self explanatory with the rubber lines.
