Front brake problem?
Old Aug 25, 2015 | 09:02 AM
fatboy slim's Avatar
fatboy slim
Originally Posted by RANGER73
When was the last time you flushed the system? DOT5 attracts water and compress' differently. Flush, refill and bleed it.
I think Harley specify DOT4.
Old Aug 25, 2015 | 09:12 AM
hattitude's Avatar
hattitude
Originally Posted by Pete3323
I have done and had some work done recently. Changed the brake fluid cover and had the front forks changed to chrome which required the caliper to be removed. Would these possibly have caused the problem?
It has been my experience, working on boats, cars, and motorcycles, that if a problem arrises on a part/system I was just working on... it's usually something I did. Might have just aggravated a condition that already existed, or something was reassembled wrong.
I'd check the new cover to make sure it is sealing, not leaking...No leak?
Did they disconnect the caliper? If so, then I would replace fluid and bleed. If they just hung the caliper or new fluid doesn't fix it...
I'd go through the whole system.... checking/replacing wear parts as I go...
Good luck & stay on top of this... brakes are kind of important...
Daytona Glider
Feb 3, 2023 07:43 AM
Munkman
Jul 4, 2019 07:00 PM
bubbas1
Wheels/Tires
Aug 13, 2009 04:52 PM
Hotrod8975
Mar 2, 2007 04:16 PM
