drop-in 6 speed conversions?
Old May 2, 2007 | 11:41 PM
mberryhill69's Avatar
mberryhill69
Default drop-in 6 speed conversions?
Who has done it? What brand? How much did it cost you to have it done? I have a 2004 Heritage and it REALLY needs another gear.
Old May 3, 2007 | 02:57 AM
pro1955's Avatar
pro1955
Default RE: drop-in 6 speed conversions?
I watched a friend of mine who is a tech at the Harley shop, install a 6 speed gear cluster (HD) and its a no going back mod. You would not believe how much of the transmission case has to be ground away, the trans case was full of shavings. I personally would go with an aftermarket trans and sell the old one.
Old May 3, 2007 | 03:59 PM
mberryhill69
Well i read the install instructions on the BakerDD6 and it does mention the possibility of light grinding. They "say" it should fit without any grinding but you may have to.
Old May 3, 2007 | 04:03 PM
sleepneagle's Avatar
sleepneagle
I did it in Feb 05. used the HD gear set. I would do it again.
Old May 3, 2007 | 04:17 PM
mberryhill69
Did you do it yourself or have dealer/shop do it?
Old May 3, 2007 | 04:48 PM
sleepneagle
Had my dealer do it. Slow time of year and got 20% off parts and labor. I also bought a Jims 103 under the same deal.
Old May 4, 2007 | 10:48 AM
WISHBONE's Avatar
WISHBONE
BEST THING I EVER DID....RUNNING 70 AT 2700 RPM'S HAS GOT TO BE MAKING MY ENGINE LAST A LITTLE LONGER. I USED THE S/E GEAR SET.
Old May 4, 2007 | 04:53 PM
mberryhill69
Can any of you tell me what it cost you ??
Old May 4, 2007 | 11:01 PM
shineybike's Avatar
shineybike
Does anyone know if a 6 speed setup will work with a hydraulic clutch?
Old May 5, 2007 | 01:06 AM
85FXWG's Avatar
85FXWG
It will cost you $1995 for the gear set, $199 for the side cover and $500 labor to install. This is if you pay full price. I got my gear set for $1500 and the side cover for $149. Sold my 5 speed gear set for $200 and the side cover for $40 so that dropped it down another $250. It cost me after all was said and done around $1900
ORIGINAL: mberryhill69
