Side mount licence plate
Old Sep 25, 2015 | 04:53 PM
nightstermass's Avatar
nightstermass
# you need 67800199
Old Sep 25, 2015 | 05:13 PM
nightstermass
Ive been looking at many side mounts I really like this but My bikes Chrome so this will not do if you find it in chrome let me know
Old Sep 25, 2015 | 11:49 PM
Redbeard719's Avatar
Redbeard719
The Breakout uses the same mount, only in chrome.
Old Sep 26, 2015 | 12:52 AM
Next In Line's Avatar
Next In Line
I don't know if the UK plate size is the same as the NL one but you may find something better than the OEM.
http://www.cpvparts.com/
Old Sep 26, 2015 | 12:54 AM
stinkerbill's Avatar
stinkerbill
Hmmm... Thanks again for you help guys, but it looks like that's just the indicator stem/mount...
I need the full licence plate kit including the 'arm' that the licence plate mounts to that them attaches to the bike between the indicator stem and the fender strut, as you can see in the pics I posted.
Old Sep 26, 2015 | 04:26 AM
steamybob's Avatar
steamybob
The Cycle Visions 'In Close' is a neat side-mount plate, with internal LED lighting.
Old Sep 26, 2015 | 04:33 PM
nightstermass
maybe this then
Factory OEM Licence Plate Assembly
Part # 67900115 Listed at $187.50 Lic plate bracket assy separated
Part # 6790017 Lists for $49.45 is the LED Illuminator & harness
All Mounting hardware Bolts, Washers & Nuts were not Returned to me when the bike was ready to hit the road, but they list for $1.05 each.
The Frame and 4 hex screws are included as part of the LPB assy.
The Original Mount, still attached to the Bracket is Part # 68966-08 Listing for $51.25
Reflector #60123-02 lists for $4.22
Mounting block #69557-10 Lists for $7.49
Adjustable backplate #68702-07 Lists for $10.15
Old Sep 27, 2015 | 03:06 PM
Valleyvets's Avatar
Valleyvets
6th Gear
Default Axle mounted side plate UK
Not the best of photos but shows the axel mounted plate and led
The back of the mount
Old Sep 27, 2015 | 03:14 PM
Valleyvets's Avatar
Valleyvets
6th Gear
Default Axel mounted plate on Breakout
I also didn't like how high the stock Harley side mounted plate was, so installed an axel mounted bracket instead.
Axel mounted plate with original number plate
Stock number plate bracket
Axel mount with light and number plate cut to smallest legal size (standard UK lettering and spacing with a minimum 11mm border)
Back of mount
Old Sep 28, 2015 | 02:41 AM
stinkerbill
That looks great - what make is that? Where did yo get it?
