Big Weekend Ride, One Little Problem
Old Oct 13, 2015 | 01:29 PM
ChickinOnaChain's Avatar
ChickinOnaChain
Big Kahuna HDF Member
Originally Posted by Mike Lawless
I checked the key Hogpro. Nothing in there. So I got a flash like and looked down into the slot where the key goes. There was a sliver of peeled off chrome wedged in there. I was able to most of it cleared out with an exacto knife. All good now. If it happens again, I'll be prepared. Thanks for the tip!
I was hoping you posted what happened and what the problem was. Thanks.
Old Oct 13, 2015 | 10:08 PM
Gommee's Avatar
Gommee
Devil's Advocate
I put a spray of dry lube in the ignition twice a year. I use the clear spray, same dry lube I use on my ammo press.
Having the alarm system, I rarely lock it. Love the engine dis-abler.
Old Oct 14, 2015 | 01:00 PM
hattitude's Avatar
hattitude
The Deluxe rode almost flawlessly, even achieving as high as 55mpg on the stretch between Inyokern and Lone Pine. Average was just under 50 for the whole trip.
Glad you got your problem fixed...l Awesome when it's something simple!
I was up that way about a month ago. I usually get 35-38mpg on my Ultra Limited. From Lee Vining to Lone Pine and then on to Kramer Junction, I got 44mpg...!
That 395 must be a magic roadway.....!
OR... maybe it's just the decreasing altitude....
Old Oct 14, 2015 | 05:38 PM
NH Marcus's Avatar
NH Marcus
Glad you got it taken care of! In case it happens again... A few years ago I experienced a similar problem, but my ignition was already locked. I damaged my key when I engaged the fork lock, but I didn't realize it. Luckily I was finally able to unlock the ignition with the damaged key. My local dealer was able to rebuild lock cylinder so the original (spare) key worked, and I just ordered extra keys. Cost was approximately $50 for the repair.
DC4MVP
Oct 23, 2017 03:14 PM
rewog
Oct 12, 2014 05:59 PM
NewJackCiti
Apr 9, 2014 01:46 PM
citytrucker26
EVO
17
Jun 15, 2010 10:26 AM
shawn e.
Oct 4, 2008 04:15 PM
