Spark plugs
Old Jan 16, 2016 | 08:10 PM
1004ron's Avatar
1004ron
Originally Posted by sn95bullitt
I'm having a problem still with the spark plug fouling up.
Screming eagle plugs
Auto lite 65 (were in bike when I bought it)
An these plugs I put in ran it for about 10 mins and rode 1 mile around the block. NGK 5534
Are you having any performance issues?
To assess the colour of the plugs you need a good run with the engine at normal operating temperature for some time.
10 mins and a 1 mile ride it could still be on the richer cold start mixture - it it fuel injection, 91 probably not?
Carb float level might be erratic/too high.
Old Jan 16, 2016 | 08:15 PM
QC's Avatar
QC
The first 2 sets look oil soaked. Last set looks rich.
Old Jan 17, 2016 | 04:23 AM
Warp Factor's Avatar
Warp Factor
That's no surprise. From your photos, something appears to be seriously off with your fuel/air ratio, or with oil control.
Old Jan 17, 2016 | 04:26 AM
splattttttt's Avatar
splattttttt
the last two looked fine. Front may not have reached same high temp as the back, but they seemed ok for such a short ride. No fouling. Bet if you went for a ripp up the freeway, they'd be spotless.
Couple questions... Are you double checkin the gap and keeping your fingers of the electrodes?
And your ignition wires... When was the last time you changed those?
Old Jan 17, 2016 | 08:53 AM
Warp Factor
They might clean up with a hard rip down the freeway, or there may already be enough conductive deposits on the insulator that it's easier for the electricity to take that path, than jump the gap. Misfire.
I've pulled out misfiring plugs that looked a lot cleaner than those.
Old Jan 17, 2016 | 09:09 AM
FatboysFatboy96's Avatar
FatboysFatboy96
That was only after a mile. The engine seems really rich.....
Old Jan 17, 2016 | 09:39 AM
WP50's Avatar
WP50
That's not enough run time on the plugs to make a good call
WP
Old Jan 17, 2016 | 09:51 AM
Tony_N's Avatar
Tony_N
If you're only running it for 10 minutes and driving a mile, the engine is probably not up to normal operating temperature. How long are you leaving the enricher all the way out. Stock air cleaner / exhaust? Have you tried leaning out the idle mixture?
Old Jan 17, 2016 | 11:13 AM
sn95bullitt's Avatar
sn95bullitt
The wires are probably 15 years old. Bike has only 4k miles since the motor was built. I am not having any performance issues. The first 2 set smell like unburnt fuel. i have not messed with any of the air fuel mixtures. It have aftermarket air cleaner and pipes.
My biggest problem with the plugs are that i cant start the bike unless i take them out and clean them and reinstall.
Old Jan 17, 2016 | 12:34 PM
Tony_N's Avatar
Tony_N
Sounds like the plugs are fouled. After you clean them, once you get the bike started, bump the idle up a little and push the enricher in. Let it warm up a little with the idle bumped up and then take it for a good ride to get it up to operating temperature. See if that helps.
