Swing Arm Bolt
Old Dec 11, 2015 | 10:13 AM
Eightball52's Avatar
Eightball52
Default Swing Arm Bolt
Was wondering if the swing arm bolt on 84 to 88 softails is needed to be one piece across the swing arm if you are using different shocks that don't use the canisters that mount on the bolt or could you use a single bolt for each side eliminating the long bolt? Would there be alignment problems or any other problems?
Old Dec 11, 2015 | 07:22 PM
Tom84FXST's Avatar
Tom84FXST
That piece is a tube with a bolt on each side...it stiffens the frame in that area, and I believe handling would suffer from flex if it was removed.
Old Dec 11, 2015 | 07:43 PM
Jackie Paper's Avatar
Jackie Paper
Changed in 89 but mostly just all the oil being in the shock rather then the remote reservoir. Still has the spreader bar.
Old Dec 14, 2015 | 08:10 AM
Eightball52
Thanks Tom84FXST, I was wondering cause I went to a 200 tire on my 84 three years ago and did the conversion the same way you did. I used a pivot bolt kit which is similar to what is used on a 2006 softail, which is a bolt that goes across the entire length and eliminates the threaded tube. The handling has been excellent. The reason I was wondering about replacing it was because I was thinking about moving my oil filter in that area and the bolt was in the way but I'm gonna keep it up front so it gets a little cooling when riding. Thanks for your reply.
matte
Apr 10, 2026 12:00 AM
markkoby
Jul 31, 2015 03:37 AM
RidemyEVO
EVO
Feb 16, 2011 05:11 PM
GEESE
Jul 25, 2010 09:34 AM
94fatboy
Jun 20, 2010 04:44 PM
