Springer
Old Jan 18, 2016 | 01:49 PM
Mkane10136's Avatar
Mkane10136
Stage III
Default Springer
Hey, having trouble with spit & sputtering at about 1800-2000 RPM's before and after rides fine?anyone with a clue? Thanks Mike :
Old Jan 18, 2016 | 04:16 PM
H-D Nomad's Avatar
H-D Nomad
If its a carb could be jetting or dirty jets or mixture settings, Idle circuit to jetting circuit I would look at. Fuelling issues are throttle position only not rpm related just FYI.
Not really enough info given for what else it could be.
Old Jan 19, 2016 | 07:51 PM
Mkane10136's Avatar
Mkane10136
Stage III
Thanks yeah it's a carb and tried carb cleaners,fuel additive,i didn't know about throttle position I'll look in to it..
Now tonight it's about 40degrees.it spitting all over the place....thanks for your help
Old Jan 20, 2016 | 04:42 AM
H-D Nomad's Avatar
H-D Nomad
Try pulling the enricher out abit when the riding with a warm engine, does the spitting get better or worse? Sounds like it could be a little lean on the low jet or idle circuit, have you any mods, exhaust or air cleaner?
Old Jan 25, 2016 | 07:58 PM
Mkane10136's Avatar
Mkane10136
Stage III
Yeah high compression heads were put on and cam work.I pick it up about a year ago,started napping about 3 months now Thanks for ur help I'll check it out
Old Jan 26, 2016 | 09:43 AM
panz4ever's Avatar
panz4ever
Check for an intake leak
lmz5150
EVO
29
May 12, 2017 02:41 PM
lowflyer
Carburetor Related
Aug 18, 2014 08:20 PM
som69
EVO
May 30, 2013 07:47 AM
Francois.j
Nov 28, 2012 12:16 AM
FastHoss
Dec 16, 2009 02:34 PM
