2000 springer
Old May 10, 2007 | 01:40 AM
scott88s's Avatar
scott88s
Stage II
Default 2000 springer
I have a 2000 fxsts and it has a shake at 40 to 50 on the gas or off . I hav e had the rims tured and the head bearing replaced and still have the same problem . The bike has 20000 miles on it and knowone has been able to slove the problemm ,also the tires are cupping
Old May 10, 2007 | 01:43 AM
tbroenick97's Avatar
tbroenick97
Default RE: 2000 springer
A few ideas:
Im sure the wheels were balanced again when trued?
Wheel bearings? any noise from there?
I would think only other place to check would be the forks or something in that area
Old May 10, 2007 | 01:57 AM
In Memoriam Citoriplus's Avatar
May our Moderator Rest in Peace
ORIGINAL: tbroenick97
A few ideas:
On the forks, when was the last time anyone checked the oil or seals inthem?
If its cupping the tires front and rear it may need new seals and rear shocks and once they start cupping you'll play merry hell keeping them balanced properly.
Old May 10, 2007 | 02:17 AM
scott88s's Avatar
scott88s
Stage II
no noise and no sign of it after 50mph
Old May 10, 2007 | 10:44 AM
MikeyB's Avatar
MikeyB
Whatbrand of tires are you using? And the air pressure? On the front I run at least 42psi. Also I had cupping when I was running Metzeler ME88 Marathons. So I'm back to using Dunlops.
MikeyB
alandchris
Mar 3, 2014 10:39 PM
ClodeV
Mar 25, 2013 10:06 PM
waterbuffalo750
Wheels/Tires
Jan 18, 2013 09:49 PM
HeadshotSK
Wheels/Tires
Sep 17, 2011 12:09 PM
jadev
Apr 6, 2011 11:43 AM
