Weird downshifting problem.
Old May 10, 2007 | 04:29 AM
michaelbarry's Avatar
michaelbarry
Default Weird downshifting problem.
The bike has done this twice within the past week or so, I think. I know it definately did it once tonight, but it seems like it did it the other day, and I just dismissed it as my goof up. Anyway..tonight i'm downshifting..and I shift down (I think it should have been going down to third)..so I do it, hit the throttle..and it's like i'm in neutral. Pull the clutch back in..downshift again..let out on the clutch...and about get thrown over the handlebars because it seems the thing shifted down to 2nd...mind you, i'm going along at about 40 mph...pull clutch back in, shift up and all is fine...it's odd. Any ideas?
Old May 10, 2007 | 06:38 AM
Megalomania's Avatar
Megalomania
Default RE: Weird downshifting problem.
If you ask me, you were a gear lower than you thought. It happens.
Old May 10, 2007 | 07:30 AM
michaelbarry
Well, that wouldn't surprise me if it was possible that that were the case...but..when I down-shifted and let out on the clutch, it was like I was in neutral when I rolled on the throttle. So I pulled in the clutch, pushed the shifter down again and BLAMMO...2nd gear..[8D]
Old May 10, 2007 | 12:43 PM
LOWRY's Avatar
LOWRY
sounds like you're not letting out the clutch with EACH GEAR you downshift into .... that used to happen to me to. Mysteriously went into neutral.
Old May 10, 2007 | 12:44 PM
Megalomania
Gotcha. I misunderstood what you were describing. Sure doesn't sound right.
Old May 10, 2007 | 04:00 PM
Unruly's Avatar
Unruly
I had a similair problem with my 2002 FLSTC. Heres how I corrected it. I pulled off thetoe/heel shift level and then the black bushing. Clean out the bushing and grease the crap out of it. On my bike it was collecting water and grime and it was not returning to the proper position after shifting keeping the tranny in between gears. Now this is part of my maintance I do on my bike prior to riding season.
Old May 10, 2007 | 05:12 PM
michaelbarry
ORIGINAL: Unruly
Now this sounds like it could definately be a possibility. Thanks, i'll try this.
Old May 11, 2007 | 03:07 AM
69Shark's Avatar
69Shark
Funny, My shifter seemed like it was doing odd stuff lately. 2002 FLSCT. I'm trying this one too! Thanks for the question and input I ride in the rain a lot so this makes sense!
Scott
jsims002
Sep 18, 2013 07:55 PM
cmosentine
Jul 1, 2013 08:24 PM
northeastconfederate
Jan 31, 2013 10:26 AM
jp2code
Jun 28, 2012 05:06 PM
michaelbarry
Mar 30, 2008 08:20 PM
