Fuelpak3 question
Old Mar 19, 2016 | 05:59 PM
Akata's Avatar
Akata
Default Fuelpak3 question
I recently purchased a fuelpak3 for my 2016 softail slim S (stock).
On the exhaust type i selected generic the gives me 3 options
1. 2-1 exhaust
2. 2-2 (no cross over)
3. Slipons
i selected #2 but the stock exhaust has a cross over. does this matter? if so should i select #3? any help would or suggestions would be appreciated.
Old Mar 19, 2016 | 06:22 PM
Rick58's Avatar
Rick58
Why didn't you select H-D for the exhaust manufacturer and Stock Exhaust for Exhaust Name ?
Old Mar 19, 2016 | 06:41 PM
Akata's Avatar
Akata
because its not listed. my options are...
V&H
Python
Generic
Crusher
if theres a way to add HD to the list im all ears
Old Mar 19, 2016 | 06:49 PM
Rick58's Avatar
Rick58
It's showing up on my phone in demo mode.
Old Mar 19, 2016 | 06:52 PM
Akata's Avatar
Akata
ineresting...its showing up in my demo mode also. ill have to call V&H on monday. maybe they havent mapped all the options for the S model yet
Old Mar 19, 2016 | 06:56 PM
Rick58's Avatar
Rick58
Be sure to post back what you find out.
Old Mar 19, 2016 | 08:51 PM
Rocker B's Avatar
Rocker B
I would think your cross over might work like a 2-1, maybe option 1.. but I guess not with stock mufflers, calling them is best ... but how is the bike running?? if good, you probably made the right choice!! I don't think any of the FP3 maps are "designed" for use with stock mufflers.. just slip-ons or full exhaust.. also, is the stock air-cleaner of the "S" considered "high flow"?? if not, you need to change it, the FP3 assumes you have a high flow a/c..
Old Mar 19, 2016 | 09:14 PM
gpp's Avatar
gpp
I would just auto tune which ever map you use and see how it does.after you get done auto tuning I would put the moderate throttle setting in it and if you have a back firing or popping in the exhaust put in the first setting for that .progressive throttle moderate setting is great.
Old Mar 19, 2016 | 09:37 PM
Rocker B's Avatar
Rocker B
I agree!!, the AutoTune and Decel Pop features can work well, make sure if you run AutoTune, that you run it long enough, checking the Progress Tracker often and really working on filling as many rpm/throttle position cells as possible, it's not easy to fill the 80%- 100% throttle position cells, you have to hit the different rpm's multiple times.. but the more cells you fill, the better the tune will be when you hit "Finish"!!
Old Mar 20, 2016 | 02:54 AM
2015 Harley Davidson Street Bob Guy's Avatar
Is the fuelpak 3 the same thing as a Tuner?
It cost almost the same price as the Dynojet Power Vision Pro???
