head shake?
Old Aug 17, 2011 | 09:41 PM
  #31
DannyZ71's Avatar
DannyZ71
IMHO, with laced wheels, the spokes should be tested for tightness more often than you check your air pressure. Especially on bikes as heavy as these are. It doesn't take much to get them to loosen up.
Old Aug 17, 2011 | 10:07 PM
  #32
terryrh's Avatar
terryrh
I don't know...but sometimes I need one.
Old Sep 24, 2011 | 02:08 PM
  #33
BDX2's Avatar
BDX2
Just an update,
Bike is running fine and I've done some really nice trips with it, Man I'm glad I went with this bike, The FXDWG was a really cool bike but I felt like my range was soo limited.
Anyway back on topic.. My buddy bought the same bike a few weeks before me and I told him about the loose spokes. I racked up more miles than him quickly. By the time he had about 350 miles, he called me and said the same thing happened to him. It started shaking, he took it to the dealer and they tightened all the loose spokes on the back. Looks like it was just a fluke with only a few bikes, but something to look for if you recently purchased the 2012 classic.
Old Sep 24, 2011 | 02:22 PM
  #34
terryrh's Avatar
terryrh
Glad it all is working out for you. See you on the road sometime.
Old Sep 24, 2011 | 02:28 PM
  #35
fat_tony's Avatar
fat_tony
Cruisers have really relaxed steering geometry so a steering damper does not help. It could be a number of things, worn steering bearings (most likely), weird wear on the front tire, or on some models play in the rear end suspension (likely) - there are after market rear suspension braces that claim to help this although I have no experience with them. With your front end raised grab the forks at the lowest point and yank in different directions, their should be ZERO movement or play, if there is you need new bearings - 1mm of movement is too much. Check for lateral play in the rear suspension using the same technique.
thoner7
Jun 28, 2019 12:24 PM
103power
Oct 15, 2018 06:13 AM
harleyheaven
Aug 29, 2013 08:08 PM
MJHJEA
Mar 8, 2009 04:06 PM
arachman
Sep 4, 2006 06:17 PM
