riser bolts???
Old Apr 3, 2016 | 03:41 PM
Jersey Drew's Avatar
Jersey Drew
Default riser bolts???
a friend of mine made me some riser extensions for my BO. i know the size of bolts i need but from what i have read people say the bolts need to be grade 8 but the stock bolts seem to be grade 5. do they have to be grade 8? also the grade 8 only has a small portion of the bolt threaded with that be enough thread to bolt into the stock risers after the extensions are installed?
Old Apr 3, 2016 | 06:43 PM
stal94gt's Avatar
stal94gt
You should measure to see what length bolt you need so you get plenty of threads in the riser. Adding extensions will also increase the torque you put on the bolts when riding. I would use grade 8 bolts if it was my ride. Bolts are not real expensive but having your risers fail could lead to disaster
Old Apr 3, 2016 | 07:02 PM
WVDevil's Avatar
WVDevil
Grade 5 is strong, 8 is stronger. They even make 9. Check Mcmaster.com if having trouble. They ship very fast
Old Apr 4, 2016 | 08:58 PM
the_enforcer's Avatar
the_enforcer
I just added some risers to my breakout tonight and I stuffed some grade 8 back in there instead of grade 5 like what came out. Wont hurt anything. The grade 8 I got were longer for the risers but had the same length of threaded section. I would search around for the right ones.
Voony
Aug 4, 2011 04:28 PM
SgtMic
May 5, 2010 05:00 PM
Xenomorph
Feb 1, 2010 07:32 AM
chromedome
Nov 13, 2008 11:58 AM
rubiconMike
Aug 24, 2008 08:39 PM
