Early Softail solid rear wheel hubcap?
Old Apr 16, 2016 | 04:08 PM
Greenblood's Avatar
Greenblood
Default Early Softail solid rear wheel hubcap?
Fitting a sprotor to my softie, need to shift that ugly disk to the left side, same as the front.
That means removing the disk from the right side, which will then show the horrible casting holes where the disk was. Does anyone know of a disk replacement or hubcap that will fill this space nicely? It will need a 2" hole I imagine.
Cheers
Steve
Old Apr 16, 2016 | 04:20 PM
Jackie Paper's Avatar
Jackie Paper
Not sure if this helps but my Harley front OEM star rim came set up for one or two brake rotors. It came with a cover if only one was used. Might see if dealer can get a cover that may work
Old May 9, 2016 | 10:53 AM
Greenblood's Avatar
Greenblood
Still not getting anywhere with this. The wheel is apparently a centreline spun aluminium solid disc wheel, 16 inch. I think a nice disc spacer, polished up with some shiny dome heads on the studs will look nice. Just need to find a spacer...the spacer needs to be about 2" id and 4" od.
Cheers
Steve
Old May 9, 2016 | 01:26 PM
Tom84FXST's Avatar
Tom84FXST
When I put a sprotor on mine with a stock wheel...this is what I used to cover the "ugly" side.
http://www.jpcycles.com/product/220-490
Or if that price too much you could use one of these.
http://vulcanworks.net/store/Harley-...y-Spacers.html
mmhyson
Wheels/Tires
Feb 19, 2017 05:09 PM
awilson40
Wheels/Tires
Sep 17, 2015 02:08 PM
erSito
Wheels/Tires
Feb 9, 2014 12:24 PM
rocknrod
Jul 26, 2013 05:50 PM
L_Brown
May 30, 2009 04:18 PM
