Slim pull-back riser kit question
Old May 21, 2016 | 11:20 PM
MNtadpole's Avatar
MNtadpole
Default Slim pull-back riser kit question
So getting lower back pain on my current stock set up, so I was looking into the pull-back riser kit. There is a note indicating '15 and newer with abs need a brake line...since the stock length won't allow for an extension. So my question comes in concerning doing this apparent brake line install. I am familiar with manually bleed a car's brakes and all...but since my bike has ABS I was curious if that complicates the procedure? I want to say that I heard that only a shop can work on ABS brake systems...something about using a digital technician tool to purge the ABS of possible trapped air. Is this true?
Old May 21, 2016 | 11:49 PM
FLS103's Avatar
FLS103
When I changed bars on my 2013 Slim with ABS and had to replace the brake line I used a vacuum bleeder. That was two years and almost 14,000 miles ago. The ABS functions the same as it did when new and I have had no issues to date.
Old May 22, 2016 | 01:11 PM
MNtadpole's Avatar
MNtadpole
What did you do exactly? Did you install the new line, then bleed it from the master cylinder....once the new line was free of air to install it where it meets the bikes abs unit? Then bleed from the relief valve at the caliper?
Jerry L
Jan 7, 2020 08:38 PM
gtrplyr
Aug 8, 2017 12:13 PM
Cornel
Jul 10, 2015 09:59 AM
Jeepin79
Nov 21, 2014 11:12 AM
tekman
Mar 14, 2014 10:24 PM
