Deuce undesirable?
Honestly, remove that big piece of plastic holding on the license plate and lower it so it doesn't look like a dirt bike, it makes a world of difference.
Sure the seller did not have any trouble getting rid of it at that price. Half of NADA and they do the research I would assume to get their price. Know my city appraises my 04 at 10500. Would not bother me a bit if the would cut that in half.
Buy what looks pretty on you. There just like women, put a bag over their head and they are all the same.
I've trimmed the license plate frame/holder down and you're correct. It does look better. I'm on the fence as to lowering the bike as I don't want it to ride stiffer when my wife goes with me. She has a bad back and it's already tough on her to ride.
Here's a rear shot of it as it sits now.
#awesome by Will Kronk, on Flickr
I did it with bolts before switching to the Shotgun Shock. The Shotgun is fantastic, but I wouldn't use bolts is you're concerned about the ride.
Originally Posted by Village IdiotĂƒÂ‚Ă‚Â™
My rear wheel is a semi-solid off of a Softail Custom. I had it powder coated black. I think it's a a 17x6.5 and fits a 200 on it. It really fills out the fender but it's a huge pain in the ***. I have to remove the rotor to get the wheel off.I did it with bolts before switching to the Shotgun Shock. The Shotgun is fantastic, but I wouldn't use bolts is you're concerned about the ride.
Dropped the front 2" with mono tubes and the rear to the top of the rim line.
Seems to work
Looks good. I'm currently running a set of Hogpro Diablos. The rear is a 18 X 5.5. Tire is an Avon 180/55/18 Cobra. Fills the rear in nice. Not too bad to pull it other than the usual stuff.
Seems to work
Seems to work
Of course, I'm wanting to build myself a hard tail chopper, so you know I'm OK with a rougher suspension.
The 3" tank lift doesn't hurt with the flow of lines as well. Apparently the Deuce's fuel pump sits a little further back than a normal Softail, so you're not losing as much fuel capacity as on a standard Softail tank. I usually fill up by 170 miles.
Before I chopped it off completely, I trimmed it down. You can trim it so that it still holds the plate but hides the plastic. It cleans it up a lot.
