Newbie! 1996 Springer - Modifications question
Its an amazing feeling being part of such a great heritage..
My question(s).. I just inherited a 1996 Softail Springer! It is fully stock but has not run in over 5 years. I am getting a new carburetor and having it "Gone-Thru" to make it road worthy.. My first question is I would like a bigger front tire and a larger rear tire(180) .. I have searched and I know both can be done BUT can they be done "reasonably" I am a blue collar guy and proud of that, I still need to support my family but would love to make this bike mine. Also would like a drag bar set up. So, is any of this possible realistically? Any comments would be greatly appreciated and again very excited to be on the road with you.
Thank you all in advance
JT
I can't give you specific answers to your questions but, in general, anything is possible. How reasonable or realistic it is depends on the state of your bank account.
Congrats on the new ride. Post pictures when you can.
bars are easy an cheap just make sure they work on springer front ends...you may find lots of routine front end stuff is different for a springer but it's well worth it because they are rare an cool.
as for the rear tire.....180 will take some work, aftermarket stuff an MONEY. I hear a 140 will fit, might need a quarter inch spacer behind the pulley to move it out so the belt will clear the tire. some say a 150 will work with a half inch spacer an making sure no bolts are sticking inside the fender, turn them around an use chrome acorn nuts on the outside...you luck may vary. you may have to trim the belt guard too. I'm probably going to try a 150 soon.
I had a 94 an I put a 160 on a Deuce wheel. I turned all the bolts around, got a skinny belt an pulley....You have to pull the primary to install the skinny belt, that's why I'm going to try a 150...might go 160 later if I need to do primary work. I picked up a hand full of spacers an had to start the axle in the wheel, shove the brake caliber in an slide the axle the rest of the way through to get it together.
that's a little led run/brake/turn/plate light I got from demon customs
Thanks
