oil sock
Old May 23, 2007 | 06:38 PM
stglideblk's Avatar
stglideblk
Default oil sock
have 2001 flstc wtih gear drive, cams, pistons, crane ignition, mikuni carb, and v&h 2 into 1. problem is the oil will not stay in sock long enough to check it, as soon as motor is off oil drains into crankcase.
Old May 23, 2007 | 11:59 PM
Nasty350LT1's Avatar
Nasty350LT1
Default RE: oil sock
What is an "OIL SOCK" ?
Old May 24, 2007 | 01:06 PM
fxstcguy98's Avatar
fxstcguy98
There is a check ball in the oil pump that is supposed to stop that. Either the check ball needs fixed or the oil pump may need to be replaced if it draining that quickly.
thumbbuster
Oil Archive (no new posts)
Jan 1, 2019 05:51 PM
hpw2406
May 8, 2017 08:17 PM
ronnie41653
Oct 23, 2013 08:48 AM
peted172
Shovelhead
May 19, 2010 05:26 AM
cabrillopr
Nov 4, 2009 06:13 PM
