2003 FXST Headlight Dims
Old Sep 8, 2016 | 02:40 AM
Elevatorman58's Avatar
Elevatorman58
Stage III
Default 2003 FXST Headlight Dims
The headlight on my FXST will go dim.. But even when it is running dim the dimmer switch still works high_beam and low_beam just too dim. Some of the time it will stay dim for quite a long time then brighten again. Both with the switch in the high_beam and low_beam position. Anyone know what is happening with this. Is it a common problem?
Old Sep 9, 2016 | 07:51 AM
E8USMCRET's Avatar
E8USMCRET
Check your battery terminals they could be getting loose. Might want to replace the bulb as well.
Old Sep 9, 2016 | 08:24 AM
stinkerbill's Avatar
stinkerbill
Sounds like a flat/low battery to me
Had similar symptoms on my MT-01
Old Sep 9, 2016 | 10:43 AM
Mike Lawless's Avatar
Mike Lawless
After checking the battery connections as E8USMCRET points out, the way to know for sure what's going on is by doing a voltage check of both the battery while it's running, and then at the headlight plug. That will either tell you where the problem is....or is not. If the voltage is good at the headlight plug, like around 13v while running and the headlight is dim, then it's probably the headlight itself or the headlight ground.
Diagnosing problems like this can be a process of elimination. Finding where the problem is not narrows down the list of places where it is.
Old Sep 9, 2016 | 04:05 PM
Clammy's Avatar
Clammy
First thing I would check is the connection at the bulb. Is it tight? Is there corrosion? Then go from there.
Cheers!
Old Sep 10, 2016 | 03:12 AM
DayzedAndKunfoozed's Avatar
DayzedAndKunfoozed
Had a switch grounding out on my bars one time a long time ago on a dirt and trail I had that messed with the light voltage.
Teddy D
Panhead
Apr 2, 2018 07:55 AM
svarnster
Mar 24, 2016 02:34 PM
lloydrtr
Nov 4, 2011 08:10 PM
RobsSoftie
Jun 25, 2009 09:08 PM
blueglide88
EVO
Aug 14, 2008 02:55 AM
