2015 vs 2016 engine
Old Nov 8, 2016 | 03:58 AM
jswatzell's Avatar
jswatzell
Default 2015 vs 2016 engine
Hello. I need to ask a question about the 2015 engine on a Heritage. I know it is a 103 ci but the 2016 is labeled as a "high output 103". Is there any difference between the 2015 vs the 2016? I have ridden the 2016 and was very impressed with the power. Now I have found a nice 2015 but I want to know if it's going to have the same power. Probably a dumb question but I don't know where to look to compare specs. Thanks
Old Nov 8, 2016 | 04:15 AM
EagleRay's Avatar
EagleRay
Basically the same engine but with a modified A/C and different cams that provide insignificantly more torque at lower rpms. Similar characteristic like the SE255 cams.....but still EPA compliant.
Old Nov 8, 2016 | 04:28 AM
Prot's Avatar
Prot
Cams and air cleaner mostly.
The difference is sort of minimal and you can achieve better results on your own with aftermarket parts and tuner.
Before they took the 2015 to 2016 comparison down on Harley's site, it was only around 4 pound feet of torque.
High output? More like Hyped Output.
Old Nov 8, 2016 | 05:49 AM
Nostradamus74's Avatar
Nostradamus74
I guess 2016 also has 50mm TBW throttle body.
Old Nov 8, 2016 | 06:01 AM
EagleRay's Avatar
EagleRay
At least the Breakout has. I can't imagine the MoCo using different engine setups within one engine model line.
Old Nov 8, 2016 | 07:35 AM
jswatzell's Avatar
jswatzell
Thanks for the responses y'all. As usual this group has the answers I can count on.
Old Nov 8, 2016 | 10:40 AM
Renoir1's Avatar
Renoir1
Yeah, as said above I believe the difference is about 4 ft lbs of torque.
I test rode a bunch of bikes over the summer before deciding on a nice used '13 slim. I didn't really notice much of a difference riding the '16.
One dealer did tell me that the '16's have 'beefier' electronics, whatever that means.
Old Nov 8, 2016 | 11:16 AM
OldEnuf2NoBtr's Avatar
OldEnuf2NoBtr
The "High Output" engine is really nothing more than a marketing tactic.
Old Nov 8, 2016 | 12:59 PM
Snowyone's Avatar
Snowyone
Default diff
It may have been just the machines but my Brother and I were waiting around for his Dyna to be repaired and the salesman got tired of looking at us I guess. Talked us into taking a test ride(real hard to do haha). We took a 2015 Heritage and a 2015 RK that had the High Output engine. There was a bunch of difference in the power. I know the're different models and all and I do own two softails and was trying to convince my brother of the Softail way but after changing back and forth few times the RK was mucho better. He ended up buying the RK he liked it so much.
Old Nov 8, 2016 | 01:50 PM
EagleRay's Avatar
EagleRay
The RK came with a different gearing and different final drive ratio - rear pulley 68T vs. 66T on the Heritage, which would increase the rear wheel torque. Plus as I mentioned before the HO engine comes with cams that deliver more torque than the non-HO (appr. 9.5 ft-lb = 10%). Nothing that couldn't be compensated by installing a proper A/C, cams, exhaust and a proper dyno tune.
Obviously the salesman knew his job....
But most important: Your brother is happy!
artsbest
Apr 8, 2016 07:19 PM
RexD
Sep 9, 2015 06:47 PM
Snarvol
Nov 7, 2010 11:17 AM
slowrollin
Jun 22, 2010 02:50 PM
FLHXXHLF
Dec 9, 2008 04:04 PM
