21" to 19" front wheel conversion on '09 FXSTC
Old Nov 25, 2016 | 01:15 PM
Gaz B's Avatar
Gaz B
Default 21" to 19" front wheel conversion on '09 FXSTC
I know it's been done by plenty of folk already but I thought it might be of use to those contemplating doing the same one day if I drip feed my winter project progress on the forum over the next few months.
Don't get any free time during the week so it'll be whenever I can sneak out into the garage over the weekends.
Starts tomorrow!
Old Nov 26, 2016 | 01:04 PM
Gaz B's Avatar
Gaz B
Default Front fender
I'm going for a 19" x 3" stainless rim and 40 spokes using my existing hub and a 120 x 70 x 19 tyre
I have a friend who owns a custom shop in Germany who's very kindly offered to build me the wheel, just need to strip mine down and send him the hub which should be happening sometime next month all being well.
After months of trawling eBay this week I eventually found a suitable donor front fender, and would you believe it's the same paint as my original, black with the twin silver pin stripe!
It's got some battle scars and it's slightly twisted. The seller didn't know which model it's from but on comparing the size with my mates bike I'm pretty sure it's off a Sportster Super low which has a 120 x 18" tyre so with a bit of tweaking here and there it'll be a very reasonable fit.
The underside of the donor fender is 145 mm, perfect for the 120 wide tyre.
It's only 150mm wide at the fork lug mounting points, a shortfall of 25mm but it won't be a problem putting a 13mm (1/2") offset in the bracket, after all the origininal fender has a massive angled offset being such a narrow fender between the WG forks.
Attached Thumbnails 21" to 19" front wheel conversion on '09 FXSTC-img_0249.jpg   21" to 19" front wheel conversion on '09 FXSTC-img_0250.jpg   21" to 19" front wheel conversion on '09 FXSTC-img_0251.jpg
Old Nov 26, 2016 | 01:12 PM
RedHogz's Avatar
RedHogz
A quick question if I may? Why are you dropping down to a 19 inch? Style, ride-ability, being a one off? I don't recall seeing any conversions like that here in the Colonies. Just curious.
Old Nov 26, 2016 | 01:17 PM
Gaz B's Avatar
Gaz B
Twisted bracket all sorted.
Tomorrow I'll offer it up between the forks and see how it looks but won't be tempted to mess with it until I have the new 19" wheel on the bike.
Attached Thumbnails 21" to 19" front wheel conversion on '09 FXSTC-img_0253.jpg
Old Nov 26, 2016 | 01:26 PM
Gaz B's Avatar
Gaz B
Hi,
Style mainly,
I do like the look of bikes with wider, smaller wheels and tyres and apart from the skinny front wheel the FXSTC was a good blank canvas to start with and I think this modification complements the theme I've been going with.
I've read all the comments on improved handling but to be honest that's just an added bonus as I've never had an issue with the original setup.
Old Nov 26, 2016 | 07:04 PM
rquest's Avatar
rquest
This thread also has me baffled, most likely anyone on here with a 19 incher would probably trade up to a 21 in a heartbeat!
Old Nov 26, 2016 | 09:50 PM
Wrenchy's Avatar
Wrenchy
FWIW I tossed a 17" fatboy wheel on the front of my NT with a 140 tire... handles much better than the 21" rubber banded crack/tar snake finder
Old Nov 26, 2016 | 10:38 PM
rquest's Avatar
rquest
I had an 18 incher on this bike, handled great but looked like it ran into a wall. The 21" is classic HD!
Attached Thumbnails 21" to 19" front wheel conversion on '09 FXSTC-2012-05-27-15.33.36.jpg
Old Nov 27, 2016 | 01:22 AM
Gaz B's Avatar
Gaz B
Quite simple really, I don't like the skinny wheel.
Old Nov 27, 2016 | 09:17 AM
Longplay's Avatar
Longplay
I also am in the throws of making that decision. I also have style tastes similar to Gaz B. I have an older metric bike with roughly similar lines to my FXSTC (07). Like my FX like no other, but I am still giving thought to having a 19" front wheel as well. My metric runs one and I like the stance. With the shorter diameter, but taller rubber, the overall is almost the same at the end, so it is all a matter of the look.
Yeah, think I saw something about better ride or handling with the more rubber for the road, but I am pretty sure it is more a mental improvement than actual. Either way, it is driven by our individual idea of style. And for me, that is making me look at something to move into a 19" when I get back to my bike.
