Brake upgrades
Old Feb 8, 2017 | 05:36 PM
Ink83's Avatar
Ink83
Originally Posted by rbeamj
Snowyone. That is pretty much the setup I'm looking to do but with a composit rotor and pads from lyndall.
My my concern is the stock 16 inch wheel. Wondering if there will be an issue with the 13 inch rotor and PM or Jaybrake caliper.
As you can see in the pic I posted, with that 13" rotor, from the center of the axle to the outer edge of the calliper would maybe be 14.5" max. So I'd assume there'd be enough clearance. It looks as though the pm calipers are slightly more compact in size over the jay brake, this may or may not make a difference between the two with room
Either way I can give you exact measurements next Thursday
Old Feb 8, 2017 | 06:54 PM
Griff012FLHX's Avatar
Griff012FLHX
Is it possible to go dual on the front....
Old Feb 8, 2017 | 07:52 PM
rbeamj's Avatar
rbeamj
Grit. On non-ABS bikes you can do dual brakes. It involves changing the right front tube, master cylinder and adding the calipers and rotors.
The 03-04 Duece had dual rotors and such so parts should be easy to find. The challenge is on ABS bikes. Not sure the ABS will work even though the CVO breakout came with it stock
Old Feb 8, 2017 | 08:38 PM
Snowyone's Avatar
Snowyone
Default Clearance
The problem I've run into with previous brake conversions with spoked wheels there is less room to fit the caliper in because of hub width and spoke angle. One advantage the six piston caliper has is it's overall size except for length seems smaller. I know you'll like the additional braking force but I'm not hip to what it will take on your wheel.
Old Feb 8, 2017 | 08:42 PM
Snowyone's Avatar
Snowyone
Default where did u find it?
Ink83...that is the exact wheel brake combination I've been trying to find for my Crossbones. Please share where you got it...pleaseeeeee
Old Feb 9, 2017 | 05:32 AM
Ink83's Avatar
Ink83
As you would know no one really makes any decent brakes for springer. It's really simple, you just need to make, or buy a brake hanger like mine that accepts radial mount calipers like on hydraulic forks. Buy the opposite side radial calliper to the side you want the brakes on your springer. So if you have a left side setup, then by a right hand calliper and flip it over. These are not specified to be used for springers and if you ask any of these company's they won't know what the hell you're talking about. These are calipers specifically meant for hydraulic forks.
If you buy a hanger already made, make sure you check what years it's for (eg pre 99 or 2000 and up) so you can get the right calliper.
Pm 6 piston calipers for a 13" rotor are great as you don't need any extended mounts or anything, the calliper has extended mounts moulded into it, so it's a simple as bolting it straight on. From there, you will need to make 3 new axles spacers for the side the brakes on to get the calliper centered on the rotor, and keep the wheel centered obviously
Not sure if I explained that clear enough but feel free to ask anything
Old Feb 10, 2017 | 07:20 AM
WKNDS's Avatar
WKNDS
The wheels look like Invader Wheels, but I think he got
the ones from Lowbrow Customs.
hth,
T.
Old Feb 10, 2017 | 07:25 AM
Ranfrol's Avatar
Ranfrol
Originally Posted by tommyglide
Consider checking with QTMI for a Brembo package. I bought a Brembo 4 pad caliper for my Heritage and it performs way better than a populat 6 piston I had on prior.
Not to hijack this tread, but Tommy where did you get your setup?
Old Feb 10, 2017 | 01:30 PM
Mabbott's Avatar
Mabbott
I'm curious as to what you notice differently when upgrading to a 6 piston caliper and a larger rotor on a non abs bike? The amount of rubber touching the road compared to a car is tiny and definitely our limiting factor. Our front tire can only grip the road so much until it locks up. Do you just get better feel for the brakes so you can really feel that point before it locks up? Does upgrading your brakes on a non abs bike really make you stop faster? I can stop fairly quick as far as non abs bikes go and feel like upgrading brakes isn't going to give my tires more grip to not lock up.
Old Feb 10, 2017 | 02:19 PM
rbeamj's Avatar
rbeamj
To answer your question. You get a better feel less fade and better initial bite.
Yes the tire will still lock up and will do so with less lever effort giving you more control.
Right now now the softail brakes are real stiff to pull and no real feedback when braking.
In my case I was living in California where lane sharing is allowed. On three separate occasions I had cagers cut me off. I would grab a handful of brakes and stomp on the rears. In all cases it felt as if there was no front brake while the rears activated the ABS with ease. It was scary because it felt as if the bike didn't have enough braking.
Luckily i stopped in time as I was going fairly slow (35 mph) but it was enough of a scare to make me realize I need better front brakes.
Having said the above, the cost difference between upgrading to a floating rotor and caliper of stock size and going to a 13 inch rotor and caliper is negligeable. So why not just get the best possible combination you can for the money.
In my case I want the composite pieces from lyndall as they guarantee 50k miles if you use their pads and rotors.
I could save about 200 with steel rotors as the price of the calipers in either 11.5 and 13 are the same.
Qtmi has a 12.6 inch braking kit that includes steel rotors, 4 pad calipers and associated pads made by brembo.
Another option i on I looked at is a radial mounted caliper but the bracket alone is 200 plus you have to source a caliper from a crotch rocket. I don't like this option as it takes away from the look of a Harley.
