Front tire
Old Mar 4, 2017 | 06:00 AM
toe's Avatar
toe
Stage I
Default Front tire
Morning,
I have a '09 Fat Boy and I'm going thought two front tire's to one rear. And they are wearing more on the right side than the left on the front tire. I have been running Commander II. Any ideas why?
Thanks for your help,
Toe
Old Mar 4, 2017 | 09:28 PM
imboden's Avatar
imboden
I have the same tire with no problems. I know that doesn't help. You are sure everything is spaced and lined up correctly? Bad wheel bearings could make it run off. But I would think you would feel that...
Old Mar 5, 2017 | 07:58 AM
heybaylor's Avatar
heybaylor
what tire pressure , and how often checked?
btw, the left turn is way wider than the right, right turns scrub more
Old Mar 5, 2017 | 08:30 AM
RedHogz's Avatar
RedHogz
Have you had the fork assy apart? How does it ride, straight and true? Do the handlebars look perpendicular and straight to the forks? You might want to measure from your axle on the right to the frame, then the same on the other. Compare your findings. This will help check for a bent or tweaked fork tube and/or lower leg. If everything checks out OK, I'd suspect a bad bearing.
oldsoldier181
Aug 8, 2018 02:27 PM
trucker7775
Jul 7, 2017 12:39 PM
MOTOKILLER
Feb 14, 2011 12:10 PM
MOTOKILLER
Jun 17, 2010 12:38 PM
roadking07
May 20, 2008 09:18 PM
