2015 48-running lights/blinker problem
Old Apr 9, 2017 | 04:22 PM
2015Harley48's Avatar
2015Harley48
6th Gear
Default 2015 48-running lights/blinker problem
When I turn the key to full on start, the left blinker flashes once and the front and rear running lights are off.
If I remove the front bulb the rear stays on, if I remove the rear bulb the front stays on. In those states, neither bulb blinks.
Lights on right side work fine, as do head light, brake lights and flashers.
When you activate left side turn signal you get rapid flash on the turn signal indicator.
Before I tear into the connectors under the tank, any suggestions?
Old Apr 10, 2017 | 04:01 PM
ccain529's Avatar
ccain529
I used to have a 48 and have a little experience with this.
I'd look for a bad ground or a pinched wire somewhere. If none are found, you have to ask yourself a few of questions:
1. Have the bars been changed recently?
2. Has the seat been off and wires moved around?
3. Has any aftermarket stuff been added?
If yes to any, these are good places to start when trying to trace the fault.
Aside from that, all I can think is that maybe a connector is loose. The connectors for the rear indicator/stop lights are all under the seat. Disconnect them and make sure all of internal connectors are in line by pushing the wires on the back of the connector toward the connector itself.
Also, you may want to ask the mods to move this question to the Sportster forum as there may be some folks there with additional knowledge.
JacobEF
Electrical/Lighting/Alarm
Oct 27, 2019 07:47 AM
Frenchyrider
Sep 12, 2017 01:42 PM
Seal
Jul 19, 2016 07:01 PM
Adumb
Sep 7, 2014 02:34 AM
johnnyocc
Oct 25, 2011 06:03 PM
