Can't afford dyno
Old May 2, 2017 | 11:18 AM
Edwars123's Avatar
Edwars123
Stage IV
Default Can't afford dyno
Ive fallen on some tight times and just can't afford a dyno or hired help so just looking for advice. I have a 2000 flhtc 88ci . S&s stealth ac , bassani road rage b1 , dyna tech ignition, Yost kit for carb. Looking for some advice as what jets I should be useing I am running a 45 slow and 185 main with about 2 turns out on the af screw. Any advice is helpful thanks in advance.
Old May 3, 2017 | 11:23 PM
kkiley's Avatar
kkiley
That is a good starting point. What issues are you having? Idle, mid-range, top end? What do the plugs look like? I run a 190 main in mine.
Old May 4, 2017 | 12:55 AM
OldEnuf2NoBtr's Avatar
OldEnuf2NoBtr
Sukz to be U.
Old May 4, 2017 | 10:00 AM
kkiley's Avatar
kkiley
Originally Posted by OldEnuf2NoBtr
Sukz to be U.
Should be old enough to be grumpy. I don't think he needs your advise at this point in his life.
Old May 4, 2017 | 11:21 AM
FattyMcJ's Avatar
FattyMcJ
I'm running 48/185 on mine.
The guy before me had a 50 pilot in there, I felt that was a bit excessive and brought it down a step.
Old May 4, 2017 | 05:34 PM
langwilliams's Avatar
langwilliams
go buy some plugs...rn12yc fits an they're cheap...after you change jets or do an adjustment pop a fresh set in an ride it while an look at them...if they are whitish you're lean, black you're rich....a light grey tone an you're right on.
Edwars123
Carburetor Related
May 6, 2017 06:16 AM
burgerusmc
Mar 1, 2013 09:24 PM
ahhwataday
Mar 5, 2012 08:12 PM
guitarbug
Exhaust System Topics
Jan 29, 2009 05:57 AM
Greybeardrider
EVO
Sep 18, 2007 10:17 AM
