kickstand issues
Old Jul 28, 2017 | 08:36 AM
splattttttt's Avatar
splattttttt
Only PITA gon be the spring Freak
Rockah just replaced one a d was real smart about it.
Be stuffed washers in between the coils to spread them out so that it hooked in easy peasy
Old Jul 28, 2017 | 09:00 AM
Freak Show's Avatar
Freak Show
i have a shop i go to that does all the work i've had done on all my bikes for the past 13 years. I'll let them do it
Old Jul 28, 2017 | 04:29 PM
ChickinOnaChain's Avatar
ChickinOnaChain
Big Kahuna HDF Member
When I put my kickstand down, I bump it, to make sure it's all the way forward. I've never had an Issues of it folding up on me.
Old Jul 28, 2017 | 05:18 PM
Freak Show's Avatar
Freak Show
i keep my foot on it when i put it down to keep it in place, but as soon as i put the weight on it, it kicks back. so for now i check it a few times before i walk away. finding my bike on it's side would make me sick
Old Jul 29, 2017 | 01:04 AM
Gaz B's Avatar
Gaz B
Right, I get it now........
Forgive me if I have this slightly wrong (stock stand removed a couple of years back) but from what I remember with the bike stood upright you'll be able to sweep the stand back and forth as often as you want and at full stroke in the foward position it should be parked waiting to engage between the the two locking tabs. It's only when the bike is leaned over that the stand engages between the tabs.
It sounds to me that yours is trying to flick back from fully forward before it's even being lent over to engage and it could that the spring body is binding on the iron work which would encourage it to flick the stand back to the retract position.
Worth checking the spring has been fitted to the correct fixing points, maybe someone can clarify with a photo?
Old Jul 29, 2017 | 04:06 AM
Gaz B's Avatar
Gaz B
​​​​​took this pic at the dealership this morning.
check both ends of the spring to see if it hooks in the same orientation as the photo,
Last edited by Gaz B; Jul 29, 2017 at 06:08 AM. Reason: Too many typos using the mobile phone
Old Jul 29, 2017 | 08:27 AM
Freak Show's Avatar
Freak Show
Thanks for taking the picture, i'll check
Old Jul 29, 2017 | 07:38 PM
checkers's Avatar
checkers
Shimming with washers is not needed. You tube shows the method using the kickstand as the lever and loosening the attachment nut enough to swing the stand forward and spring will fall off. Rehook it after service pull the stand to the rear and locks into place, little effort, safe and no washers or wrestling with spring.
Smarcoux
Jul 26, 2018 10:13 PM
nrob84
EVO
Jun 7, 2011 05:44 AM
Bay225
Mar 7, 2010 11:20 AM
DGDyna
Aug 6, 2009 11:03 AM
BillP.
May 22, 2007 10:39 PM
