Distribution chain tensioner
Old Aug 27, 2017 | 07:50 AM
Softail332's Avatar
Softail332
Default Distribution chain tensioner
Hi to all
Ive just open the derby cover and found out the tensioner líke this
my bike Heritage Softail classic 2012 has 30K
is it normal?
Im planning to pull out chain and fit a cam kit
but dont know wich one will fit my bike
can anybody help me?
thanks
Old Aug 27, 2017 | 10:07 AM
the blob's Avatar
the blob
Not normal unless you removed the bolt that holds the tensioner assembly in place. If not I'd be searching real hard for the missing bolt in the cam chest.
Old Aug 27, 2017 | 10:16 AM
Softail332's Avatar
Softail332
Default Tensioner
bolt is not missing I pull it off to see how was the tensioner
Old Aug 27, 2017 | 10:21 AM
Roady87's Avatar
Roady87
4th Gear
Would you, are you changing that tensioner with that type of wear? or is that good for a few more miles.
Old Aug 27, 2017 | 11:00 AM
Softail332's Avatar
Softail332
Default Tensioner
Thats what I m asking
is it too worn out at 30K?
Old Aug 27, 2017 | 02:47 PM
jkinner's Avatar
jkinner
Not too worn but I would change it while you are in there, M.H.O. Oh that's not the Derby
it is the Cam cover.
Old Aug 27, 2017 | 02:51 PM
QC's Avatar
QC
Cam choice depends on what type of riding you do.
Old Aug 27, 2017 | 05:14 PM
Softail332's Avatar
Softail332
Default Tensioner
Sorry yeah it is the cam cover
well I think I ride easy
thanks guys
Old Aug 27, 2017 | 05:20 PM
Softail332's Avatar
Softail332
Default Tensioner
I ll get these upgrade pads
Old Aug 27, 2017 | 05:43 PM
Campy Roadie's Avatar
Campy Roadie
Those tensioners are fine. It's a roller chain, it's not going to wear much more in the next 50,000 miles. Put it back together and don't use those no name tensioner shoes. Or, if you indeed do cams and want to replace the shoes, I'd use OEM.
