middle tank divider and speedometer removal- search term help
Old Sep 12, 2017 | 12:07 PM
roofcrash's Avatar
roofcrash
Default middle tank divider and speedometer removal- search term help
Can anyone tell how are these tank dividers called? cant find the search term and would like to get one.
any tips on what to expect after removing the speedometer? is it difficult to install comparing to my nut-screwing-skills-only in a home garage? thanks
Old Sep 12, 2017 | 12:20 PM
brakeless's Avatar
brakeless
Can't see any pic, nor can I tell what yr and model you have, so kinda hard to help. But most of those flat things in the center of a tank are called Tank Panels, unless you have a dash panel. So in order for anyone to help you with your speedo question we need to know where it located too. I can only guess it mounted on the tank? if so, it's pretty staright forward. Kind of a plug and play sorta thing. Best bet is to get yourself a service manual.
Old Sep 12, 2017 | 12:23 PM
roofcrash's Avatar
roofcrash
heres the speedo and the panel, thank you
Old Sep 12, 2017 | 05:39 PM
Al'sFXSB's Avatar
Al'sFXSB
The black panel you are pointing to is the console. To remove, you'd carefully use a pick to CAREFULLY pry up the bar & shield emblem and underneath there is a nut that connects the console to the tank.
Old Sep 12, 2017 | 10:37 PM
stal94gt's Avatar
stal94gt
It sounds like the op wants to install a black line dash. Depending on what year the softail is will determine if you need to swap out your fuel pump plate.
Old Sep 13, 2017 | 12:47 PM
RoadTrippin''s Avatar
RoadTrippin'
I had the same situation on my '13 Heritage. You have to pry it up SOFTLY and you'll see the nut. If the panel has never been lifted or removed, you're going to think there's another bolt somewhere. I searched and searched to find any info on another nut or bolt somewhere. Turns out it was just on there really good, due to it had never been lifted before. The speedo is just a plug and go. Good Luck. Oh, and a lot of patients helps.
varnesj21
Nov 16, 2018 03:08 PM
DJ_Playaing
Harley Davidson Videos
Oct 29, 2016 12:56 AM
cgtrigg
Mar 4, 2013 02:46 PM
inkslinger73
Jan 10, 2012 06:35 PM
Naz_Man
Sep 26, 2007 06:13 AM
