Michelin CommanderIIs
Old Sep 17, 2017 | 11:51 AM
JekyllnHyde's Avatar
JekyllnHyde
Originally Posted by gamble71
Yeah, besides the excessively short mileage life, that's another indication something's wrong in the front. Only problem is, it's really hard to judge the springer front end and parts for it ain't cheap
At first i thought it might have something to do with the springer front end but then I saw that others who don't have springers are experiencing the same thing.
I was curious so I just measured the tread depth on my Avon Cobras (90/90-21 front and 200/55R17 rear) that have exactly 6271 miles on them. Here are the tread depth measurements on them new and current. (measurements were taken from center of tire). I also factored in the TWI (Tire Wear Indicator).
A tire actually has 1mm less before they recommend changing because the TWI takes up 1mm of depth. So on new tires that claim they have 5.2mm of tread depth you actually have 4.2 before you get to the TWI. I typically run 38psi for the front tire and 40psi for the rear.
FRONT TIRE
New: 5.2mm
Current: 3.5mm
Difference: 1.7mm
TWI: 2.5mm left before they reach the TWI
REAR TIRE
New: 6.8mm
Current: 3mm
Difference: 3.8mm
TWI: 2mm before they reach the TWI
The numbers indicate that the front tire is wearing at a slower rate than the rear.
If I did my math correctly (and it's possible I didn't lol), the front tire is wearing at a rate of 1mm every 3688 miles. New, the front tire had 4.2mm of tread before it reached the TWI. 3688 x 4.2 = 15,489 miles. The rear tire is wearing at 1mm every 1650 miles and new it had 5.8mm of tread before reaching the TWI. 1650 x 5.8 = 9,570 miles.
I doubt I'll get 15,000 from the front and 9500 from the rear because I think tires wear at a slightly higher rate as the miles add up. More realistically I'll probably get 13,000 to 13,500 out of the front, and about 8000 to 8500 from the rear tire.
Old Sep 17, 2017 | 01:16 PM
gamble71's Avatar
gamble71
That's where I'm at on the rear... nowhere near that on the front
Old Sep 17, 2017 | 01:26 PM
JekyllnHyde
Are you getting uneven wear from the front tire? The mileage you're getting out of them doesn't seem right, even with a 21" wheel. You should be getting at least double that. Were you getting the same results from other brand tires? You're right about the springer, its tougher to troubleshoot what the problem might be. But I'm assuming there is one.
Old Sep 17, 2017 | 02:29 PM
gamble71's Avatar
gamble71
It came with the standard Dunlops, but it's been so long ago I don't remember what they got. The wear pattern seems to start more on the left, but seems to even out the further I go. Seriously thinking about going thru the front end and start replacing it til we figure out what it is
Old Sep 17, 2017 | 04:39 PM
JekyllnHyde
yup, that's what I'd do too. Check your wheel bearings to if you haven't already. Good luck.
Old Aug 3, 2019 | 06:00 AM
bassnman's Avatar
bassnman
Just changed out my rear Mich Commander II on my 013 Ultra, rear tire had 19,500 mi it was not down to the wear bars, could've went another 1000 mi.
ran 37-38 psi, so far these tires are serving me well..
Old Aug 3, 2019 | 09:43 AM
Bobster109's Avatar
Bobster109
I just changed to the Michelin Commander II's, I have 2500 on the rear and 2000 on the front. So can't really say about the mileage I will get yet, but I can say it would have to be horrific to go to another tire after doing a 1600+ road trip on these tires, they made my Heritage ride so much smoother and handle better than the American Elites I replaced them with that I will sacrifice some mileage for the grin they give me on the highway. Unbelievable the ride quality.
I am just wondering since these are more of a touring tire, if some that ride more aggressively could do better mileage and performance wise with the new Michelin Scorchers's??? Would like to know what the real difference is in these two tires? But I sure am liking these Commanders on the Heritage for the less aggressive riding I do.
Old Aug 3, 2019 | 09:57 AM
soldierbot's Avatar
soldierbot
I run commander 2s...18/130 on the front and 18/150 on the back. Run both tires at 40 psi and I get about 5k on the back and 7.5k on the front.
gearhead1937
Jul 27, 2017 05:12 AM
tom7tom11
2014-2024 Touring Models
Sep 6, 2015 02:22 PM
JaronB
Jun 8, 2013 12:49 AM
Hitechluddite
Aug 10, 2010 04:53 PM
RanD
May 6, 2008 10:26 PM
