Which oil filter ?
Old Oct 1, 2017 | 10:04 PM
GinsengSullivan's Avatar
GinsengSullivan
High Performance Cleanable Oil Filter...
http://www.dkcustomproducts.com/outl...k-ocof-crm.htm
Old Oct 1, 2017 | 11:02 PM
Amanelot's Avatar
Amanelot
I've used these on 2 separate harleys so far. I'll never own a bike without one.
Old Oct 2, 2017 | 04:21 AM
HKMark23's Avatar
HKMark23
Here's what I use:
https://shop.gopurepower.com/pure-po...rt-pp8110.html
When I bought mine 4 years ago it was rated at 22 microns "absolute". Now, somewhat tongue in cheek I expect, its rated at 1 micron "nominal".
For an explanation, read my post above.
Permanents are the way to go. Paper filters have been known to be internally flawed, (torn open), so they filter nothing and the user will never know. Paper filter bypasses typically do not have a progressive bypass valve as permanents normally do, which means on cold starts and when you're "given er", no filtering takes place within the paper ones. Inspecting the guts of your filter at each oil change is always reassuring. Paper filters are,, paper.
I wouldn't purchase a permanent filter out of parsimony, because I don't believe they save money when "everything" is taken into account. They're a superior filter and that, IMHO, is why you should buy one, if you buy one.
Old Oct 2, 2017 | 11:03 AM
tmilo1000's Avatar
tmilo1000
I no longer use the K&N filters. The nut at the base of the filter seems to be a good idea until it strips and you have to get creative to get the filter off since it does not have facets at the base a oil filter wrench can use. I'll go with the OEM filter. I might consider the reusable filter in the future.
Old Oct 2, 2017 | 05:10 PM
vizcarmb's Avatar
vizcarmb
I get a chuckle when posters put that they are not affiliated with "SAID" company.
So what happens if you are and post it online? Does that mean you get in trouble with the moderators? I go with Stock filters since they are like 8 or 10 bucks.
Dyna7
Jun 25, 2018 04:13 PM
brokefootkenny
Apr 6, 2018 05:22 PM
Electraglideclassic1966
Sep 22, 2015 02:39 PM
mikeallenbrown
Sep 3, 2011 02:11 PM
Bubba Zanetti
Apr 13, 2007 02:15 AM
