Idle issues
The technique for setting the mixture screw is to count how many turns it took to close it, then open it the same amount plus 1/4 turn. If the mixture screw has been messed with and is not in it's stock position, then start around 1 3/4 turns....
Once the bike is warmed up and idling, you're ready to adjust the mixture screw. Turn it in (closed) until the rpm changes and/or the engine starts to stumble... turn the mixture screw SLOWLY... once it stumbles, back it out (open) until it runs smoothly and then add 1/8 turn.
Note: some twin cams will not stumble when you tighten the mixture screw, mine didn't.. in that case, just open 1 3/4 turns and go from there...
When you make a change to the mixture at idle, you'll sometimes need to re-adjust the idle screw. Once the idle and mixture is set, blip the throttle. If it's smooth with no backfiring through the carb, you're there! If it hesitates or backfires through the carb, open it 1/8 turn and check again. Once it's smooth, I take it for a ride to make sure... I'm looking for smooth acceleration and no back firing through the carb from low to mid rpms (in the proper gear of course)...
The proper adjustment is usually between 2 & 3 turns... if you have to open it 3 1/2 or more turns, it's time to bump up the size of pilot jet...
Good luck.. it's a little time consuming, but you'll get there...
For your amusement....... I hadn't rebuilt/tuned a CV40 carb in 15 years when I did mine. After the carb rebuild, my bike was WAAAY rich, and would not idle... I had the carb off 4 times, checking and looking at stuff... I finally just sat there staring at the exploded carb diagram... I just knew I was missing something very obvious... it's like trying to proof-read your own paper... very hard to do... then I saw it, I had installed the needle valve on top of the plastic spring spring holder, instead of under it (I have no idea why)... that's only about an inch higher (more open) than it should have been... felt like an idiot. I turned a 20 minute tune job into a 3 hour frustration.. but I finally got it right!
What's killing me is that when I try to put the idle back to 1k (I adjust at around 800 by ear) it inevitably drops to about 500 and then eventually stalls. So I pull up to a stop and it revs at 1200 or so and then drops to 500 and then quits. It always seems to go to the same 500 place no matter what I do.
Last night was interesting in that it didn't hang as much at high idle but went right to to a too slow idle. Hopefully it's mostly operator error which is fixable. I have all the stuff that was suggested from CVPerformance coming soon so I'll be cleaning the crap out of it.
I read also that you shouldn't adjust mix/idle on the side stand. I'll try the method you outline with the bike upright and see.
Thanks again for your time. I'll let you know how it goes.
Also idle related... I know you said you dealt with your vacuum fuel petcock. I forgot if you switched it out or just turned the diaphragm around.... but erratic idle can be fuel flow.... make sure the in-tank screen is clear, the petcock is flowing steady, and you capped the vacuum port for the OEM petcock...
Also, I've never used the "back out (open) until it floods" method for finding the sweet spot. Seems to me it would leave it very rich...
Keep us posted...
I had an ironhead with a super b that suddenly started to idle very high. reinstalled the intake 15 times at least trying to cure an air leak I couldn't find. swapped the carb out with the same model from ebay and it ran fine. I think I'm going to pick up either a mikuni ez carb or an aftermarket cv. Otherwise I'm taking it to the mechanic.
I'm at a loss
I'm at a loss
While the carb is off again, you can inspect the manifold to head connections to ensure they are leak free...
It sure sounds like you covered all the bases... gotta be something simple I'd bet... Just like you can't proof-read your own text, it's hard to check your own work.... do you have friend that knows carbs that can go over your work with you?
Good luck...
