Softtail standard
Old Jan 27, 2018 | 01:12 PM
Softy0327's Avatar
Softy0327
2nd Gear
Default Softtail standard
Hi I'm new here I have a question cause I don't well can't spend alot of money taking my bike to shop but my softball started acting up so I've changed the spark plugs wires changed fuel filter Map sensor ckp sensor help it's still acting up
Old Jan 27, 2018 | 01:19 PM
98hotrodfatboy's Avatar
98hotrodfatboy
Ok, year make and model..? How many miles..? Any engine upgrades? When does it have running issues, idle? Cruising? Racing? Need more info....
Old Jan 27, 2018 | 01:22 PM
Softy0327's Avatar
Softy0327
2nd Gear
06 softtail standard no up grades won't idle and when I do take offiy won't stay running 25000 miles prob
Old Jan 27, 2018 | 01:29 PM
K9F's Avatar
K9F
Bad gas or clogged fuel filter(s) would be my first port of call. Alternatively there are several documented cases of damaged wire to the crank position sensor on this forum and on others (see link below). Welcome to the forum!
https://www.hdforums.com/forum/ignit...on-t-idle.html
Old Jan 27, 2018 | 01:30 PM
Softy0327's Avatar
Softy0327
2nd Gear
It's got new gas and new filter
Old Jan 27, 2018 | 01:39 PM
K9F's Avatar
K9F
Sock filter on the fuel pump? Any other work you've done recently? Check the crank position sensor wiring out!
Old Jan 27, 2018 | 01:41 PM
Softy0327's Avatar
Softy0327
2nd Gear
It all looks fine yes new filter
Old Jan 27, 2018 | 01:44 PM
K9F's Avatar
K9F
Get a multimeter or rope in someone that can wield a multimeter with effect and check the crank position sensor wiring out!
Old Jan 27, 2018 | 05:09 PM
the blob's Avatar
the blob
Clean iac valve in the throttle body.
Old Jan 28, 2018 | 07:02 AM
98hotrodfatboy
Do you have a Factory service manual and did you check for fault codes?
