2003 fxsti...won't start
Old Feb 5, 2018 | 03:32 PM
my80shovel's Avatar
my80shovel
Stage II
Default 2003 fxsti...won't start
got ready to start bike about a week ago..had started before ...now it just turns over, but won't fire..has fuel but apparently doesn't have fire somewhere...could it be ecm...any ideas...
Old Feb 5, 2018 | 03:41 PM
Noisy Cricket's Avatar
Noisy Cricket
Check the battery voltage. Should be 12-13V Might be enough to turn over but not enough to throw a spark. Pull a plug and see if you have fire at the plug.
Old Feb 6, 2018 | 04:21 PM
my80shovel's Avatar
my80shovel
Stage II
no fire at plug?.....any other ideas...checked battery voltage...(12.9-13)
Old Feb 6, 2018 | 05:09 PM
press, lean, and roll's Avatar
On all ignition systems there is a primary and secondary side. You need to figure out which one is not working.
In a nutshell the primary is all the low voltage components. It tells the secondary when to fire. The secondary is the high voltage components and plugs and plug wires and coil. Well technically, half of the coil is the primary side.
Old Feb 6, 2018 | 08:44 PM
the blob's Avatar
the blob
My bet is a bad sensor. Like the crank sensor or less likely , bank angle sensor.
Almost forgot, I'd check and wiggle the ignition switch first as that's a problem area too.
Old Feb 6, 2018 | 08:47 PM
Noisy Cricket
I'm not sure if this means you had no fire at the plug or you didn't understand my question. Pull the plug and rest it on the side of the jug, then crank the engine and see if it has a spark. This will verify if it is a fuel or electrical problem.
Sinistral_leo
Jul 16, 2017 06:12 PM
477966
May 1, 2016 07:18 PM
nervehead
Mar 4, 2013 11:57 PM
bustert
Nov 30, 2009 07:01 PM
HDF Tech
Electrical/Lighting/Alarm
Jul 5, 2005 08:26 AM
