Passenger Pegs
Old Feb 28, 2018 | 07:47 AM
Pelone5k's Avatar
Pelone5k
Default Passenger Pegs
I have a 2016 fatboy and the passenger peg keeps falling down during rides. Seems a little loose, but there doesn't seem to be any way to tighten it. Any suggestions?
Old Feb 28, 2018 | 08:14 AM
TGlynn's Avatar
TGlynn
I had the same thing happen. Had to go get a new spring washer. I should've bought multiples. Passenger pegs are sagging again after only a year.
Old Feb 28, 2018 | 08:20 AM
b bop n bob's Avatar
b bop n bob
I will preface this by saying I've never owned anything newer than an '07, so I might be wrong .There should be a D-shaped spacer/washer with a slight curve to it between the peg and the mount. Remove the bolt and it should fall out. With 2 pair of pliers (gently) bend the spacer a little more and re-insert. (bit of a PITA). That should increase the friction between peg and mount.
Old Feb 28, 2018 | 08:24 AM
b bop n bob
I will preface this by saying I've never owned anything newer than an '07, so I could be wrong. There is a d-shaped spacer/washer between the peg and the mount. Remove the bolt and it should fall out. With2 pair of pliers (gently) bend the spacer and re-insert. That should increase the tension/friction between the peg and mount.
Old Feb 28, 2018 | 08:32 AM
Pelone5k's Avatar
Pelone5k
Thanks Bob, I'll give it a whirl!
Old Feb 28, 2018 | 11:44 AM
jkinner's Avatar
jkinner
My Deluxe did the same thing, I went with a nut and bolt with the spring washer, a little tight but they stay in the up position.
Old Mar 1, 2018 | 06:14 AM
cocky's Avatar
cocky
J & P has the spring D washers that have a tab that makes them a little better than the HD ones. A bolt and nut is the sure cure.
5TIME
Apr 12, 2013 10:33 PM
69onmy09dyna
Oct 1, 2011 08:11 AM
Dog Father
Aug 28, 2010 07:44 PM
3rdgear
Nov 17, 2009 09:11 AM
topkick
Mar 25, 2008 03:14 PM
