Installed the Fangs. Left side hitting engine guard.....
Old May 7, 2018 | 05:57 AM
ChromeJunkie's Avatar
ChromeJunkie
Since we are talking about fangs, has anyone installed them on a Deluxe? I have been told that they won’t fit because the turn signals are tucked too far to the back and it makes no sense to buy them if they won’t fit.
Old May 7, 2018 | 10:37 AM
PA1195's Avatar
PA1195
I've installed them on several, bothTwin Cam and M8. HD sells them to fit the Twin Cams, but not the M8's yet. They have a cutout to clear the turn signals. But the fastener hole spacing is further apart on the M8 and the lower hole needs to be re-drilled. Install the top of the fang then hold it against the lower fork fastener's head and tap the fang with a soft hammer to mark the hole location. Remove and drill a new hole then install. They may need to be twisted forward to clear the engine bar if it's installed.
Old May 7, 2018 | 11:24 AM
ChromeJunkie
Ok, thanks. It’s on a twin cam, Wife’s 2014 Deluxe. Thanks again.
Old May 7, 2018 | 01:07 PM
PA1195's Avatar
PA1195
You may have to file the holes in the fangs for a better fit. And the turn signals can be loosened (internal nut inside driving lamps above them holds them on) and moved forward on the bracket bar if more clearance required.
Old May 7, 2018 | 06:09 PM
ChromeJunkie
Thank you very much. I was wondering whether the turn signals could be moved forward. I’m going to take the “fangs” off of my Heritage and put them on her Deluxe. Thanks again. 👍
Old May 8, 2018 | 07:29 PM
ChromeJunkie
Thanks for the info on the fangs. I took the ones off my Heritage to put on the OLs Deluxe and fit without having to alter the holes or move the turn signals. Thanks again for the help.
Old May 8, 2018 | 11:23 PM
PA1195's Avatar
PA1195
Clearance depends on the shape of the turn signals (flat or bullet) and the crossbar. Pre-2018's they sell two sizes and shapes of fangs...one for Touring and one for Softail. For 2018 the fork head spacing is different (further apart holes required due to new bending valve forks) and that spacing even varies between '18 Softail models. HD might make some that fit when the 2019's come out and they can afford to bring in new accessories. Not much for mid-year parts this year.
Old May 11, 2018 | 12:54 PM
Fishbones182's Avatar
Fishbones182
Just installed mine yesterday. They clear The engine guard fine about 1/4 gap at full lock either direction. They work great. Reduced buffeting big time.
Old May 11, 2018 | 01:43 PM
ChromeJunkie
The fangs did fit the OLs Deluxe, plenty of room for the turn signals and they also f didn’t touch the crash bar. However, once installed, I couldn’t get the damn windshield back on. I have a couple of tricks up my sleeve, so first chance I get, I’m going to try them.
Old May 11, 2018 | 08:52 PM
PA1195's Avatar
PA1195
This applies to the Deluxe models. Two people make it easier but my wife was busy so I did it ok.
The windshield frame to fangs can cause an interference if the shield is installed per the factory instructions (insert into lower mounts and swing the top shield back into the uppers). The two lower "forks" of HD's quick release shield (mine for 2018 is the Heritage style P/N 57400329) that slide over the slotted rubber doughnuts will hit the fang's forward face when the shield is bent forward and can't be pushed back. What I did on 2018 and earlier Deluxes was push the rubber doughnuts fully into the upper and lower forks with no attaching hardware. Then loosen any nuts and bolts used to assemble the windshield's frame. That loose slop allows for the extra width of the fangs that are placed up against the fork frame on the deluxe.
Remove the four short upper factory fork fasteners one at a time (T27 Torx) and partially insert the longer bolts into the forks through the fang's holes (lower one being drilled new to match the spacing). That keeps the metal fork parts in alignment. Remove the lower two bolts and place the lower windshield forks with rubbers over the holes as vertically as possible and insert the bolts with a washer each. Then remove the two upper bolts, swing the shield the small remaining distance into place, and repeat the fastening through the upper rubbers. Align everything and tighten the fork fasteners to spec'd torque per shield instructions. Finally tighten the fasteners that hold the shield to its frame. Rotate the fangs forward edge as required to clear the engine bar (if installed) when the forks are turned left or right.
Removal requires simply unbolting the windshield as it can't be swung forward off the rubber mounts with the fangs installed. If more clearance is desired when installing things unbolt the driving light/turn signal crossbar and temporarily set it on the front fender over pads. Note the steel bolts screw into an aluminum treaded frame under the chrome overlay so be careful at first to not cross thread them.
