1992 FLSTF Headlight & Running lights Out
Old May 22, 2018 | 12:57 PM
ept5777's Avatar
ept5777
Stage III
Default 1992 FLSTF Headlight & Running lights Out
Hi my special 1992 Fat-Boy (Only 33 ever painted in this special color and Decal in 1992) Headlights & Running Lights have gone out? Blinkers, tail lights, brakes and starting up is all perfect with no problems. Please if Possible tell me what I should be Checking on first without pulling the tanks with my volt meter. All 15 amp breakers check good, and grounds to all seem to be fine so I do have the Headlight out and both running lights out and getting no power to the either.
Thanks in advance for any help in advance!
I have used both Parts Manual & Service Manual since 1992 on this Girl so I have common knowledge of this Girl.
Old May 22, 2018 | 01:11 PM
ept5777's Avatar
ept5777
Stage III
One last Note Please, the High Beam dash light is not lighting up either! Thanks in advance.
Old May 22, 2018 | 03:06 PM
racerkvn's Avatar
racerkvn
First thing I'd recommend doing is pulling the ignition switch out and taking it apart to clean ALL the contacts and springs. If any of the contacts are worn (ignition contact for instance) swap the worn contact with the "acc" position contact. You'd be surprised how many issues are solved just by taking the switch apart and cleaning it as well as swapping the worn ignition contact. Not saying that is your problem but if it were mine, that is the first thing I would check. And it doesn't cost a dime.
Kerosene
EVO
Sep 21, 2017 02:45 PM
checkers
Electrical/Lighting/Alarm
May 20, 2017 06:21 AM
DoubleTake
Aug 14, 2015 09:57 PM
jlbreaux
Jul 9, 2013 07:00 PM
bear68
Apr 3, 2010 06:17 PM
