Great it worked so well on the back. I only had weights on the back tire, 3 weights on each side of the rim. I removed them and find now I don't need them.
I just installed ride on into the front tire. brand new bike so stiff sidewalls. Stuff kept on oozing out when trying to squeeze it in even with valve at 2:00. .
Or read the instructions prior to installing:
1. Rotate the tire into which Ride-On is to be installed so that the tire stem is between the 3 and 9 o’clock position (bottom half of the tire).
