Ignition issues
Old Aug 11, 2018 | 08:27 AM
Shadow775's Avatar
Shadow775
2nd Gear
Default Ignition issues
I have an 04 nitetrain. When hot it starts to cut out and die. After cooling off it starts back up. Replaced crank position sensor and still has same problem. Please help.
Old Aug 11, 2018 | 08:36 AM
QC's Avatar
QC
What condition are the fuel lines and fuel filter?
Have you cleaned the IAC?
Is the Throttle position sensor working?
Old Aug 11, 2018 | 08:39 AM
Shadow775's Avatar
Shadow775
2nd Gear
Only happens when motor is hot. Threw a code for the crank position sensor. Thats why I replaced it.
Old Aug 11, 2018 | 09:11 AM
PDB17UltraRG's Avatar
PDB17UltraRG
You need to take a good look at your wiring harnesses and lines that run near your exhaust system could as simple as a lose connection. Go over it slowly things come lose over time.
Old Aug 11, 2018 | 10:31 AM
Shadow775's Avatar
Shadow775
2nd Gear
Will do that.
could it be the ignition coil?
Old Aug 11, 2018 | 10:16 PM
QC's Avatar
QC
Unlikely, but they do go bad. Usually when they get hot.
Do you have a voltmeter to test it?
Pothole914
Oct 8, 2019 09:01 PM
bmur66
EVO
29
Jun 3, 2017 09:29 AM
02fx4dude
May 15, 2013 07:17 AM
txphatboy
Aug 30, 2011 12:56 AM
sideshow bob
Jun 29, 2010 01:15 PM
