Speedometer Problem.
Old Jun 29, 2007 | 12:32 AM
Freakofnature's Avatar
Freakofnature
Default Speedometer Problem.
I was riding down the road today and noticed that my speedo was bouncing up and down (not just a little bit but bad, back and forth between 60 and the 30 mph mark) any Ideas what could be causing this, any thing I should look for? The bike is a 05 FLSTF. Thanks for any help or sugestions.
Old Jun 29, 2007 | 12:59 AM
In Memoriam Citoriplus's Avatar
May our Moderator Rest in Peace
Default RE: Speedometer Problem.
Sounds a little like a flaky sending unit or a poor connection under the dash. If its still under the warrenty I would let the dealer deal with it. If not, start checking the connections. You could get lucky and find one that's a little loose.
Old Jun 29, 2007 | 01:08 AM
Freakofnature
Thanks, I just had some work done to it and the tank was taken off so I thought it was probably a loose conection but I figured Id throw the question out here before messing with it. Ill be taking it back to the shop that did the work on it A.S.A.P. so they can fix it. Thanks again.
Old Jun 29, 2007 | 01:21 AM
If somebody had the tank off the connections under the speedo would be THE first place I would start looking, or have whoever did the work doing it.
Good luck and let us know how you make out.
Littleredcrate
Mar 12, 2021 11:46 AM
brittcrowell
Jun 4, 2013 12:33 AM
Superfly3176
Mar 4, 2012 05:06 PM
CroFromGuntown
May 15, 2011 08:33 AM
mgoblue3
May 15, 2007 09:26 PM
