Run and turn functions work correctly
Old Oct 9, 2018 | 10:29 PM
vincitydaimo's Avatar
vincitydaimo
Stage I
Default Run and turn functions work correctly
Hi all,
I have a 2008 Rocker, with integrated run/turn/brake lights.
When I apply the brakes the brake lights flash once and then go back to 'run' brightness.
Same effect with either front of back brake.
Run and turn functions work correctly.
Old Oct 10, 2018 | 12:49 PM
Shellfish20's Avatar
Shellfish20
Sounds like either a bad earth or dodgy microswitches (less likely if both front and back brake are affected)
Steve
Old Oct 12, 2018 | 04:00 AM
j33ptj's Avatar
j33ptj
Are they aftermarket? Original did not have that, so you may check the wiring of the "new" lights?
RJ
Old Oct 14, 2018 | 05:01 PM
4 inch pistons's Avatar
4 inch pistons
Did you get it new? Sounds like you have a custom dynamics adapter triple play that lets you program your lights. Anything under the seat?
Old Oct 14, 2018 | 06:25 PM
Bone Doc's Avatar
Bone Doc
Welcome to the forum from central Texas.
It's possible the run/brake/turn module is bad.
Old Oct 23, 2018 | 11:20 AM
4 inch pistons
update?
sheardc
Feb 13, 2021 05:54 PM
Shellfish20
Sep 26, 2018 07:53 PM
06SGWA
Jul 28, 2013 12:42 AM
lowridermike
Dec 16, 2009 11:47 AM
blz2503
May 21, 2009 12:09 PM
