Need help to understand this problem!
Old Oct 28, 2018 | 02:41 AM
HogRocker's Avatar
HogRocker
Stage III
Default Need help to understand this problem!
Hey guys, I have a 06 Softail Deluxe and recently, every now and then, when I go to start it up, both my Trip A and Trip B gets reset. I can't figure out what's causing this. It's just a but frustrating being that I use Trip B to keep track of the mileage for my oil. If it helps the bike is fuel injected. I appreciate any help!
Old Oct 28, 2018 | 04:53 AM
Kingglide549's Avatar
Kingglide549
computers cause this.
Bad juju to have on a simple HD.
Old Oct 28, 2018 | 07:30 AM
RANGER73's Avatar
RANGER73
Bad electrical connection with the ECU
Old Oct 28, 2018 | 07:41 AM
d_slat's Avatar
d_slat
Start by checking your battery. You can have it load tested or put a meter on it and see how low the voltage drops when you are cranking it over.
Old Oct 28, 2018 | 07:43 AM
gdishman's Avatar
gdishman
I would check the battery voltage and cable connections are clean and tight. You could have a battery that is at the end of its servicable life. When the starter tries to spin it pull the voltage so low which causes the system to reset.
Battery voltage should be at lease 12.67 volts
Battery voltage while cranking at lease 9.6 Volts
Old Oct 28, 2018 | 07:44 AM
Pitbull_Dallas's Avatar
Pitbull_Dallas
Mine will do the same thing and it's a sign that your battery is beginning to give out. With a weakening battery, the voltage drop you get when you hit the starter is enough to cause the odometer to reset. I view it as a battery early warning system.
Mine did it to me just the other day, so it's time to start thinking about a new battery..
Old Oct 28, 2018 | 07:47 AM
Jackie Paper's Avatar
Jackie Paper
Bad electrical connection. Does the same thing when you remove the battery. You need to start at the battery and work to speedometer connection. Put a voltmeter on the charger wire or battery and see what voltage is going to when cranking. Below 9.6 means bad connection or worn out battery or a battery that needs a good long low (below 1 amp always) amp charge
Old Oct 28, 2018 | 07:49 AM
kel03's Avatar
kel03
Good info. Never come across it, but now aware.
jfstewart
May 4, 2018 03:52 PM
chrismacca1983
Electrical/Lighting/Alarm
Aug 17, 2016 12:08 PM
rudester123
Sep 18, 2012 06:43 PM
rerelli
Sep 1, 2012 03:19 PM
jackavelli
Mar 31, 2010 05:47 AM
