Yup, your right. Different connectors. But here is another for $29 that has the blade connectors, and includes two of them. I might buy this and have a back up as my other Harley horns dont like to get wet.
The Wolo Air Horn works great and is very loud, but does not fit under the frame wheer the stock horn is. My previous post, #6 above, links you to another post where I show the install of the Wolo Horn on My Cherry,
Sorry, its fifty... You can throw away the bracket and just put the bolt through the existing tab mount on the bike. I had to bend the tab forward slightly, but its a e-z five minute job.
Hey, thanks for the suggestion. I just put this horn on my bike today. Definitely louder than that pathetic POS horn it came with. This kinda crap pisses me off. You buy an expensive bike and it comes with a horn that sounds like a frickin roadrunner cartoon.
So is that the #69060-90H HD accessory horn (same as 2014-up touring)?
Also will it work off the 2018+ softail wire connectors for the crappy beep beeper?
