Swapping from new era design to older...
Old Nov 22, 2018 | 05:59 PM
splattttttt's Avatar
splattttttt
Default Swapping from new era design to older...
as in this case, the new 2018 Slim front end.
Will it fit the 2014?
Will it even look okay on the older Slim? In my eyes, it should since both designs are so close
Old Nov 23, 2018 | 01:46 AM
Prot's Avatar
Prot
The question is, why?
Old Nov 23, 2018 | 09:02 AM
splattttttt
The frint end on the new Slim is super sexy
Old Nov 23, 2018 | 09:10 AM
splattttttt
Compare
Old Nov 23, 2018 | 11:37 AM
Blackp5ca's Avatar
Blackp5ca
I know the triples are different but I bet you could get creative and make the fork covers work. Numbers 14 and 15 found here.
https://shop.outpostalaska.com/oempa...c_FRONT_-_FLSL
I believe the newer softails all went up in fork diameter (41mm to 49mm?) so the triples wouldn't work. Being an all new frame design I would expect the neck of the frame is completely different.
Another option would be to use some Low Brow customs fork covers. I used a set on my old Blackline, had to cut them down a bit as they are designed for the 39mm sportster forks but they fit (just) on the 41mm forks. Gives kind of the same look as the 18 Slim.
https://www.lowbrowcustoms.com/39mm-...uds-black.html
Old Nov 23, 2018 | 03:33 PM
splattttttt
I like what you did with yours. Not that far off from what I like on the new Slim.
Guess what I’m really wondering if the entire assembly can be retri fitted to the older neck
Old Nov 24, 2018 | 12:50 AM
Prot's Avatar
Prot
Get yours powder coated black as that is the biggest difference in appearance. While it is apart, change the internals and you will end up with something better.
Old Nov 24, 2018 | 05:48 AM
splattttttt
Haha, true. Or buy the new Slim
Stuntmeat
Jul 25, 2018 05:28 AM
Stuntmeat
Jul 16, 2018 06:57 PM
