no start no nothing
Old Apr 17, 2019 | 03:10 PM
raptorgabe's Avatar
raptorgabe
Default no start no nothing
whats up everyone just got done with my custom build on my 03 heritage and got it all back together and doesnt do anything when i turn the key. lights turb on i can hear the fuel pump and when i switch the kill switch on and off i can hear the pump cycling also. but when i hit the start button nothing happens no clicking no nothin. i have the fob and if i double click it th eblinkers blink like its working but not sure what else to check. i tested btoh relays and were good and all fuses are good also. any help is appreciated also battery is fully charged
Old Apr 17, 2019 | 03:26 PM
RANGER73's Avatar
RANGER73
Check that you're getting the start signal from the start relay.
Old Apr 17, 2019 | 04:15 PM
Will Belden's Avatar
Will Belden
Yah, put a multimeter at the starter connections, ensure power coming on start attempt Double check those fuses, too.
Old Apr 17, 2019 | 04:20 PM
Jackie Paper's Avatar
Jackie Paper
Community Influencer
Maybe you have not got far enough back behind it to hear it's running?........Haa..Sure looks good.
Old Apr 17, 2019 | 04:44 PM
FreedomRider's Avatar
FreedomRider
Is the battery in your FOB good?
Old Apr 17, 2019 | 04:56 PM
saltlick's Avatar
saltlick
Is everything on the right hand side clamshell working? Wondering if the wires going to the harness came loose.
Old Apr 19, 2019 | 12:57 PM
raptorgabe's Avatar
raptorgabe
the wire extensions inside the bars one came loose and now its fine! i apprecaite the help everyone . thank god it was an easy fix
tribesman
EVO
Feb 18, 2017 08:02 PM
Moneywoes
Jun 13, 2013 11:50 AM
stbob07
Sep 11, 2012 09:16 PM
Lex_Talionis
Nov 22, 2011 09:10 PM
1150A
Feb 6, 2011 03:40 PM
