2002 Fatboy Advise
Any issues with this year that I should be concerned about?
Anything to look out for?
One thing I do think is worth keeping in mind is the cam chain adjusters in the early TCs are not as good as the later ones. They went to hydraulic adjusted chains in 2007 I believe. The earlier ones are spring tension. A lot of people have never had any issues with the spring style. I personally know a guy who traded in a 2003 with 75,000 miles on it and had never had anything apart on it. However, I tore mine down to inspect them at 25,000 miles and they were pretty bad. The shoes were about halfway worn through and one side of the outer tensioner had started breaking of in little pieces. The oil pump and cam plate was showing some scoring already. It could have been put back together with new shoes on the adjusters and kept going, but I put a S&S 509 G gear driven cam set in it with the new cam plate and high volume oil pump and have been happy with that.
Mine is fuel injected and it has been trouble free. Can't speak to anything about the carbs. Stock seat on mine was a torture device, but that almost goes without saying.
My 03 has 10K on it now (4K this year)
and I'm going to check mine.
If a set of cams (accidentally) got put in there, I wouldn't cry.
My 00 only had 203's and a Thunderheader, but it had (WAY)
more mid range power than this one !!!
But it was carb'd. Dunno if that helped.
The FI is flawless , I hate to admit it. I don't like the idle though.
It sounds like a loud air compressor.
I'm keeping my 2006 FLSTFSE with almost 40,000 miles, after asking my shop what repairs I can expect vs buying a new bike.
Buying anything used, anticipate repairs. With a Harley, I believe any repairs on a clean used bike are less expensive than buying new. With any machine: ride, listen, and feel it. If it 'talks' funky, get it looked at before a minor failure causes major repairs.
My experience: 2005 FLSFSE bought new 2006
* pushing 40,000 miles ((little riding between 2010 and 2015)
* 2 transmission repairs last year (minor repairs, transmission work is expensive due to labor)
* I asked shop if I should sell and what repairs should I anticipate? Shop indicated my bike is one of cleanest, most well maintained machines they work on. They've only seen 2 other bikes with similar repairs over past 15 years; those repairs typical of hard riding.
* My shop suggested with the recent repairs and routine maintenance, I could expect another 40k-50k without significant repairs.
