Indicator Wiring
Old Apr 30, 2019 | 11:33 AM
Andylock's Avatar
Andylock
Default Indicator Wiring
Hi All,
I want to swap out the front indicators on my 2015 breakout for the ones below. The ad however is quite insistent that they 'come with 36" of cable'
So my question is, is there any reason that anyone knows why I can't simply cut and join these cables to the existing wiring, rather than routing the whole new cable back through the loom?
Old Apr 30, 2019 | 03:53 PM
RANGER73's Avatar
RANGER73
None whatsoever. Just stagger, solder and heat shrink the splices. No crimps.
And FYI, 36" is a lot of wire.
Old Apr 30, 2019 | 04:13 PM
Andylock's Avatar
Andylock
Thanks Ranger73. Yes, that's what I thought about the wiring, which is what made me wonder if I was missing something! Here's the part of the ad...
  • Feature billet aluminium housings
  • Measure 1" wide x 1/2" tall
  • Single-function high intensity amber LEDs with smoker lenses
  • Wire leads are 36" long
  • Can be mounted using the mirror stems or mirrors stem mounting bolts
  • Sold in pairs
...and the picture seems to back this up. I couldn't see any reason I couldn't just splice to the existing wiring, but not being an electrician, just wanted to check myself.
Thanks for the confirmation
Old Apr 30, 2019 | 04:18 PM
packmen21's Avatar
packmen21
+1
Old Apr 30, 2019 | 08:46 PM
RANGER73's Avatar
RANGER73
So being single function , are they going to be run or turn only?
Old May 1, 2019 | 04:12 PM
RockerE's Avatar
RockerE
if you are looking to do the minimalist signals look, have you considered something like this https://www.customdynamics.com/amber...ruflex?cat=320
I put the 5 led version in amber on my bike mounted to the bottom of my switch housings with some automotive tape. When the bike is off you can’t tell they are there at all and when they are on they are super bright. They are pretty cheap too.
Either way if you are moving from incandescent to LED lights you will likely need a load equalizer or you will get rapid flash.
Old May 1, 2019 | 08:22 PM
RANGER73's Avatar
RANGER73
I put the 5 led version in amber on my bike mounted to the bottom of my switch housings with some automotive tape. When the bike is off you can’t tell they are there at all and when they are on they are super bright. They are pretty cheap too.Either way if you are moving from incandescent to LED lights you will likely need a load equalizer or you will get rapid flash.
Depending on the year he might not.
Old May 2, 2019 | 01:15 AM
K9F's Avatar
K9F
Hi Andy, I bought Thunderbike ones and cut and spliced accordingly, my cables are buried inside the bars anyway and it would have been a mammoth task to feed all the way to the connectors. It was difficult enough disconnecting the connectors as mine were buried under the fuel tank.
Old May 2, 2019 | 04:34 AM
Andylock's Avatar
Andylock
Thanks for the info guys
Ranger73 - they are turn only
RockerE - thanks. I'll have a look at those CustomDynamics ones.
Mal, yes indeed! Which was really what prompted the question! I'm hoping you didn't have to remove the tank to get at the connectors? Did you need to fit regulators?
Old May 2, 2019 | 04:52 AM
RANGER73's Avatar
RANGER73
I think, but could be wrong, there's a learning sequence you do with you lights.
Like turning the ignition on and activating the flashers for a minute.
There's been posts about it and I'm sure someone will chime in. Or do a search.
